DN2540 Power Amp
So here's what i am thinking:
a single TO-220 DN2540 on a 200v supply. 60-80mA and a 5K:8 transformer load. 10ohm source resistor. Cap across source resistor?
unsure of power output or even if this is feasible?
thoughts?
I am looking to do a small 1 transistor / mosfet amp.
Thanks!
The TO-220 has a 15W dissipation limit. If i go to about 75% of that or 10-12W would that work?
thinking 150v supply. 60 mA to 80mA.
If i do 3 DN2540 in parallel.. could use a Edcor 1.25K:8 output transformer. might get 10W output power.
Even with a decent heatsink you would not go above 5W on the 220?
100V@50mA with 1k:8 would get ~1watt of output and be doable for 1 device.
does anyone have the ability to simulate this circuit?
Here is the result, using your data + half-realistic parameters: output power 2W for 3%THD, nominal sensitivity 500mV rms.
Nice harmonic profile, typical of SE (discounting the transformer's distortions).
Note that I find 200V uncomfortably high, but if the DN withstands it, why not.
I kept the dissipation in the DN at <6W, which means R1=27Ω, not 10, but insisting on 10Ω would either mean serious complications or a much higher dissipation in the MOS, none of which is desirable for such a simplistic circuit.
  • SEDN2540.asc
    SEDN2540.asc
