ESP P3A
C2 is ~20mm away from the FET power pin.
That is at least 15mm too far.
Next you must bring the two decoupling caps very close to each other so that the total trace length from +FET (T2) to C1 to PGND to C2 to -FET (T1) is a short as possible.
This can only be done if the FETs are moved to near each other.
In an ideal world that might be how it should be, but after looking at the original P3A layout it doesnt seem to matter much. Or Rod's original design is crap, which I sincerely doubt. 🙂
Took the previous version, rearranged a few components, added a 4.7uF cap again and switched from single to dual output pairs, for extreme situations when driving 4 Ohm loads and with enough power to drive atleast a resistive load down to 2 Ohm without trouble.
The amp PCB's have been ordered, now the waiting game begins.
now with the recommended MJL4281A/MJL4302A output transistors.
C2 is ~20mm away from the FET power pin...........
..............This can only be done if the FETs are moved to near each other.
Where have the FETs come from Andrew? Are you getting confused 😀
looks like I have gone way beyond "getting" confused.
I'll have a look in the garden for my brain, I'm fairly sure that's where I last remember it being.
Not my intention to sound negative, but why didn't you just use a single-sided pcb for this project?
As far as I see there's only one trace you would need a bypass-wire for.
Carlos
Well, firstly, some component placements was made easier and made for an overall cleaner layout. Secondly, the new version with dual output pairs needed a dual sided pcb anyway.
Besides, I'm getting them profesionally made so single or dual sided? Doesnt really matter.
Where I'm getting them made the price is the same, whether single or dual sided.
PCB's are on their way from China. Should be here sometime end of the week/early next week. I hope so anyway.
I would be really interested to know HOW you doubled the outputs. With CFPsit should not be as trivial as with EFs. Did you double the drivers as well? Did you add emitter resistors on the power devices? Did you put base stoppers? Just some question that arise...
Bye
effebi
I have already received my first PCB's, however Im already considering other options, like a P3A with 2 x pairs of TO-3 transistors.
Like the attached picture.
Ill most likely use my current PCB's but one can always consider future versions. 🙂
Bye
effebi
Emitter resistors, yes, they have been added.
It is done as recommended by the designer, Rod Elliott.
This and the other P3A threads are good tutorials for newbe PCB designers.
I saved all the PCB diagrams to my computer for careful study of the evolution of the design. I only wish the PCBs are numbered serially, R1, R2, ... etc for ease.
Finally, dear neutrality, how does your design sound?
