Just another good reason to go with bigger ports. I have four kids and can totally understand how this would happen.
Matt
Matt
Save the children!
BAN ported subwoofers! (don't forward to anyone in Congress)
At least the medics did not destroy the sub!
I use a passive radiator sub in the house and my subs in the garage have 6 inch (15cm) diameter ports, I should be OK unless a fat kid puts his leg in there.
Anyone else notice the subs power indicator is on the whole time? The first thing they should have done is unplug the damn thing.
I can't see the issue here. Sure it will have less output at fr, but may be less boomy in 8th space.
LMAO!
Right!
Ok, NOW I see the issue. Apparently they wanted the woofer to see a purely reactive load in order to acheive maximum spl, so the cheap bastards forego 50 cents worth of acoustic insulation that obviously would have smoothed at least two of the major quarter wave harmonics and only at the cost of a db or so in the published specs. It's always the bean counter and marketing department at the root of these tragedies.
- Subwoofers
- Arm stuck in woofer tube.
