Hypex UcD400OEM wiring problem
hey guys. actually I'm having problem wiring UcD400OEM to SMPS400. I almost did everything to make it sing but seems I'm missing something. I'm no expert in electronics. it would be great is someone can help me in this 🙁
attachment.php
Hi Dave,
Im in the mids of wiring up my UCD OEM as well.
Am going to used single ended input. May I ask
how is this connect up ? Also at default I believe
the module is in stand-by mode. How do you trigger
the module out of stand-by mode.
Hi Dave,
Connect negative input and ground together at the chassis ground point on the rca connector and you are good to go. You need to connect on/off pin to power ground to trigger module on, as per the manual.
