4P1L vs 4P1S
I have some 4P1S tubes and got round to running some through the tester as triodes . Compared to 4P1L with -22V grid bias for approx. 35mA anode current ~5mA/V , with 4P1S I need to back off the bias to -27V to stay within dissipation limits and get around 4.2mA/V for a 35mA target current . Anyone running these filament bias are going to cook their 4P1S pretty quickly...
It almost seems as if these are different valves in terms of biasing which is hardly subtle . Has anyone got a (preferably translated) datasheet for the 4P1S or run any triode curves ?
316a
Just opened a few from another batch and found a datasheet inside a box 🙂 Oddly although appear to have been supplied to the Czech military by the Chinese , the datasheet is in English . Ties up with the operating point tables for the 4P1L
316a
316a
Realise this is old. Thanks for sharing the English translated data sheet.
So this is a directly heated pentode.
Is it not interchangeable with the 4p1L /4n1n then? Have you tried this is something?
Interchangeable . The Chinese 4P1S hits the specs , whereas the Russian 4P1L tends to fall short . Russian 4P1L much more consistent electrically
I am still yet to try 4P1S in place of 4P1L
Strangely the Chinese valves seem to sell for a lot more money than the Russian 4P1L
cheers
316a
Thanks for the update.
Interesting. I’ve seen that there are several types of 4p1s available now. One is the usual 4p1s-j, then there are at least 2 types of others that are more expensive, one of which called a 4008 version. And then there’s the 4p1L from Russia (4n1n), which are twice the price again (in China). I believe the 4p1s was supposed to be a copy of the Russian tube.
I’ve read on this forum previously that some were getting arcing or something like that, with the little dot headphone amps. And from what I gather, it appeared to be using the 4p1s-j or the older 4p1s which has a different stamp. Which doesn’t necessarily mean there is something wrong with the tubes, as it could be the design of the circuit.
4p1s def cheaper than 4p1L in China.
