Audio dummy load
For years I've been using a wirewound resistor with some leads and banana plugs as a dummy load for testing amps.
I thought I would buy a proper one but I couldn't find anything pre-made (MCM used to sell one...)
So in case anybody is looking for ideas, here is what I made:
More details here: Audio Dummy Load
The chassis came from Landfall Systems, the extrusion from Heatsink USA, and the resistors (a bargain) at Surplus Sales of Nebraska.
Pete
Pete
Thank you for this.
In your linked article drawing "red and "black" seem to be interchanged.
I found it useful to add a small series resistor in the wire to the "hot" inner pole of the RCA socket for safety.
Some people may find it useful to have these monitor jacks floating from ground, with 1:1 signal transformers,
to avoid shorts on the scope common ground input with bridged power amp outputs (many Class D and some
OTL amps). The signal purity will be impaired of course, so I use a set of these transformers separately.
Rather than the 12 ohms position I use an "infinite" or no load position. This can be done with some types of
three position toggle switches. Useful for quick checking the damping without calculation and of great value
during power amp repair..
An additional resistor / potentiometer set will allow connection of a small monitor speaker or even headphones.
Just a small suggestion from a plain engineer ..
I decided on movable Jumpers for Adjusting my Dummy Load.
The resistors are 16 ohm 100W with a "Therm A Sheet" thermal interface to the heat sink.
Repurpose BOSE 2 stanalone amplifier
Bose Lifestyle SA2 basically a heatsink with an amplifier in it. lots being thrown away.
(Bose Lifestyle SA3 are useful because they can be used as stanalone amplifers, which I have for my car porch)
Totally based on Petes design so thank you Pete.
I implemented a 4/6/8Ohm Dummy load using 50W 4Ohm resistors. they are screwed to the top slighly curved surface, so I used 1mm thick thermal pad (Gelid Solutions GP-Ultimate)
I used my 3D printer to print tempates for the cut out & the holes, Fins are 38mm centres, resistors I used were 40mm, hence on a slant. 1mm Thermal pad visible all around.
(I did check that the pads would work with the resistor & heatsink. See graph after 36 minutes)
stl files of faceplate and templates
When I get a moment I'll put stl files up on prusaprinters for faceplate and templates.
BTW I have a spare Bose SA2, that i'll send with templates and faceplate for £20 delivered, only to UK. SA2 will be empty to save on postage costs.
