900W H-class PA Amp with Limiter
Ir 2117 change mur 1560 change mosfet change
Bf 421 change
But problem still the same
if everything ok then problem may be short or miss track.did you check amp with only hv ? if amp bulb go up and down there is no chance fault in stepper because if ic fail or any fault in stepper then two things will happen mosfet on or off in both position there is no chance that bulb will go up and down.you are doing something very wrong so no one can help you than yourself.
