The 12pw is more a 7" driver, judging by the cone area. The shallow cone and being based on a full ranger driver hopefully allow higher crossover points. This makes it a fairly unique driver for its size
Unfortunately there are no off axis measurements I can find; personally find that frustrating. Hence I've chosen the lowest X/O point (for the ribbon)
I remember Jeff B saying that a dip off axis at 3khz is not a real issue (or something along those lines) so not too concerned
Looking at most woofer offerings from scanspeak or SEAS where they do publish off axis graph, it is generally okay up to 3 KHz...
6.5 - 7" ?
8". See for example this one. If they can do it I don't see why not a full range.
H1288-08 CA22RNX
Incidentally, what I have is this one. 😱
H1597-08 FA22RCZ
Similar in many ways to the Alpair except it has a whizzer cone.
Oon
H1288-08 CA22RNX
H1597-08 FA22RCZ
Oon
I find with wide dispersion 1" tweeter coming in from 8" bass, it sounds a bit bright. It's because there is a bit of a hole in the midrange energy there, especially off-axis from the bass. You can't do anything about it except slope the tweeter response down and that is a poor compromise. So I dunno. 😱
I think its worth trying the single coil on the bass. Your tweeter filter certainly looks like 3kHz XO. But since you asked, I wouldn't be able to resist trying 1.5mH and say, 6.8uF shunt on the bass for some proper rolloff. Or even the off-the-shelf 3kHz XO values of 1mH and 10uF.
Marco_Gea was nearer 2kHz here, but the same two way idea really:
http://www.diyaudio.com/forums/multi-way/147632-classic-monitor-designs-25.html#post4428857
I'd like to keep the alpair 1st order but I can kind of see how that wd help. Hopefully the Alpair doesn't suffer from that mid hole issue and just needs a slightly lesser coil value.. It's a guesstimate crossover but close to how I want it
That tweeter will not do well with a first order slope at 3k.
I hope that you have measurement equipment.
System 7, I would not call it a wide dispersion tweeter due to it being waveguide loaded.
That said, when implemented correctly, they do sound very nice. I've heard them in a couple designs and also own a pair.
Couldn't agree more
It sounds v good 2nd order tho. I've just bought a mic but haven't taken any measurements yet
2nd order acoustic or electrical?Couldn't agree more
2nd order electric will result in a 3rd or 4th order acoustic slope, which may require you to use more than a single coil on your woofer for a smooth transfer function and phase tracking.
The tweet acoustic roll off starts just over an octave below x/o. Where I've set the coil I'm hoping the woofer is rolling off at least 2nd acoustic at x/o point. Let's see how it comes out and take it from there
http://www.heco-audio.de/en/test-reviews/heco-direkt
Another speaker worth looking at with similar design philosophy.
How is it going? Something making sound yet?
Sent from my D6653 using Tapatalk
+1 😀
Final cab design. More complicated than I thought, but it's done and the workshop will start cutting the panels tomorrow
I know the driver combo sounds pretty good but not sure how it will all come together in this cab, a bit of a shot in the dark
Man this is killing me. I only got the wood back from the yard today and there was a screw up. So I'm working through the night in the height of Bangkok summer. My flight leaves at midday so let's see how far I get! [emoji80]
- Alpair 12PW/Viawave build
