Hello Jesper,
why? Business as usual. The market for DSD is growing then there is a real demand (bigger data volume and more expensive then high-resolution ones they don´t care). Good publicity does the rest: créer un besoin in french. I´ve a lot of FLAC and DSD material. I´m using PC, MAC, Windows, IOS, OSX, Android, Foobar, Signalyst, Audirvana. DAC is from IFI and chinese no name. Tube or Transistor amplifiers. Musically I´m really happy with native DSD (Beggar´s Stones one is amazing).
I will give a try to the NoDAC idea. Minimalists design will make me really curious.
Jean-Paul
Jean-Paul
Hi Jean-Paul,
Thanks for your feedback. Sounds as if you've got some experience with various PC based audio solutions ;-)
Personally, I've had very positive experiences with DSD for playback and my main consideration is that for recording I've been told that (all) DSD recording solutions convert the DSD signal to PCM for editing and then it is converted back to DSD when the editing is done. If this is actually the case then IMHO it's less than optimal - which is why - at least at this point in time - I'm wary of how to record in DSD. Not to mention that to my knowledge there's very little software available to facilitate the path from the AD converter into the PC and then do the editing (in high quality).
Bonne chance avec le design minimaliste pour le DSD ;-)
Jesper
Jesper
Hello Jesper
perhaps open a new thread to know how native DSD material is produced?
From beginning to the end of the chain. We need the advice of a professional.
Et merci pour le message en francais!
Jean-Paul
Jean-Paul
Hello Ray,
my 2 cents to your PCB. I will give you or to the community the Cadsoft EAGLE 6.6 binaries if needed?
Jean-Paul
Thanks Jean-Paul. That is very kind and useful.
Interestingly, without seeing your post I have been working more on my own board, putting into practice what I have read and, in the main flip-flop and filter area out two boards now look very similar.
After a final check I'll probably order a batch of these boards this evening.
On the subject of keeping everything very compact, as an alternative to the onboard LP filters I have been thinking of using a TVC as a combined attenuator/LP filter, however, this implies several centimetres of wire from the flipflop to the TVC, which now seems to represent a significant compromise - any thoughts?
Ray
Hello Jesper
Jean-Paul
DSD recording probably belongs in a separate thread but as the topic has been raised you may be interested in these two links that were forwarded to me recently;
http://benchmarkmedia.com/blogs/application_notes/41262017-audio-myth-dsd-provides-a-direct-stream-from-a-d-to-d-a
http://www.mojo-audio.com/blog/dsd-vs-pcm-myth-vs-truth/
To me though, in the context of this thread, the argument is a bit academic. My interest here is based on preferring the sound of FLAC files upsampled to DSD256 and played back with a no-DAC type solution to the same FLAC files played back conventionally on my reclocked Buffalo IIIse. So in essence, in general terms, whatever processing has occurred upstream of ripping the FLAC file is accepted.
Ray
Hi Guys
May I ask, how much DSD software is out there & how many studios are really interested in good recordings & music ? When I look back into Red Book, we had good & bad recordings & for main stream music mostly where so so or poorly recorded. With audiophile recordings music wise many did not appeal to listeners so where do we go from here ?
very nice Ray, good job, very good placement!
I will go for that PCB.
Jean-Paul
Thanks Jean-Paul
Ray, even though my transformers are nestled right against my flip flops there is approx 2cm of wire from f-f output to the transformers. I have experienced no problems with this. Flip flops are dip package, on a small vero board. Even though it works fine, your PCB looks very nice and i would be interested in getting one if you are getting spares made.Thanks Jean-Paul. That is very kind and useful.
Ray
Hazard
Hazard
Thanks for the info Hazard and you'll be very welcome to a spare board, but let me get them and test one first...
I've been having a look at the sowter and silk TVCs and it looks as though, with a little creativity, they could be installed with a very short wire run to the flip-flop outputs. Hmmm..
Ray
I thought I should continue my education by progressing my own flip-flop PCB layout. I've modified the schematic to reflect the observations made previously;
and, having read some material on PCB layout and noting previous comments, I have reworked my PCB. Hopefully improving on the previous. I've added PS decoupling for the flip-flop and, by relocating the flip-flop and staying with through hole components, I have been able to get very short digital tracks.
Would appreciate any feedback on whether I've learned anything?
Overall PCB size is 48mm x 58mm
Cheers
Ray
Ray
hi
i don't need balance output, what is the best solution with no dac?
4th order LPF after the DSD wire is ok?
or i need some digital chips?
thanks
hi
thanks
Shouldn't need any 'chips'. Try your filter and let us know how it sounds...
I don't think anyone knows the answer to what is best; first you would have to define 'best'.
Ray
last modification: +5V to electrolyt and from this to MKS and them to IC.
Jean-Paul
Thanks, I've made that change.
Didn't have time to do a final check last evening but will order a batch very soon.
Ray
Thanks nautibuoy
Just want to try from the easy to hard implement NO DAC:
1)LPF
2)digital filter
3)DAC
hope to report soon
thanks
1)LPF
2)digital filter
3)DAC
hope to report soon
thanks
Thanks nautibuoy
1)LPF
2)digital filter
3)DAC
hope to report soon
thanks
You need to remember that using single-ended DSD output there will be a more or less constant DC offset of around 1.65V present. Going balanced is one way of handling that; you can always go balanced to SE downstream.
Ray
yes
now i have DC on my DAC output:
one option is CAP, but i directly connected it to my TUBE pre(unbalance), the pre output is coupled with CAP, so the output is without DC.
thanks
thanks
I thought this might be of intrest. I "assumed" DSD from Windows wouldn't be this messy.
Here's a reply from Luyben (JLSounds):
>> When will DSD be supported Windows?
The DSD is supported on Windows, but in DoP up to DSD128, the thing is that on the outputs of the I2SoverUSB board the signals are DSD native.
>> Please let me know where I can find the trail version?
You can download the driver after registration in XMOS site.
[url]http://www.xmos.com/support/usb-audio-driver-support[/URL]
You must solder one 4.7k resistor between pin1 and pin9. On the driver tab on the VID/PID lane it must be written 0x20B1/0x0002 - then the DSD native will be available with the XMOS evaluation driver.
[URL]http://www.xmos.com/support/usb-audio-driver-support[/URL]
Glad I'm using Linux, native DSD256 just works with the JLSounds board if you use a recent kernel.
Ray
I've just ordered a batch of my flip-flop PCBs; ten nice shiny boards should arrive in 10-14days all being well.
Thanks for all the assistance with optimising my initial layout.
Hazard, one has your name on it.
Now to order up the parts..
Ray
Ray
- Digital Line Level
- The Best DAC is no DAC
