I feel like this hobby has to stop!
You guys are pretty amazing.. I never actually built amplifiers with tubes or transistors. My first "hifi" consisted of an Altec amp/preame. It had 6L6 outputs and a 5U4 rectifier tube. Ran an 8" full range JamesBLansing speaker in a big box.. Yeah, mono. Turntable was a Garrard prior to the model A....
Hand-me-down from my father. Built a few speakers, got into the audio industry in time to loose my savings... Software tech support pays better. Fiddling with my music server, trying to kill some buffer underruns.
PS: could it be ridiculous to have two wide band speaker L&R stacked in front of the listener (on axis) ! Center to center could be too big for the trebles (even if they are left & right channel) with 8", 10" or more FR (bicones) ???? I always liked the sound of mono radios while they lacked of volume and bass !)
Hey Bigun,
I always liked much more the Beatles in mono vs Stereo !
But maybe it is due to Abbeyroad mixing ?!
Did you convert your stereo track with merging the two channel in one mono channel with Audaticy ?
But the simplier number of devices, I believe also the better result is comming from a standalone point source far from the side walls : those two advantages means a lot imho !
If I have lighted montor I will try to stack them with the tweeter of the stacked speaker near the tweeter of the above speaker : stereo point source and twice more efficienty (but one another tube, hey !):dice:
Btw I understand you : I have some crystals I just need to plug from 2 weeks in a socket and didn't plug it yet 😱... three pcb to solder with parts from six months and a DAC to feed with a PS from more than one years despite it's excellent AD1862 dac chip... what I prefer from this hobby is the understanding and listen to music ! The building worry me a lot.... as the compulsive buying... more and more I find those two last things to be borring and unnecessary with years, at least for me. At "only" 46, I may finish with a simplier stuff than you : a mono hp stuff with music in it like a simple transportable radio !🤐
Just fit a mono/stereo switch like in the old days..😀
I know what you mean about wallpaper..
Yes what then?
Its just something to look at until you buy a midfi mini system..
ditch all the speakers..put the amp in the loft..
You don't realise it but as you get older what happens when you have a hearing aid..its going to stop then and there is no going back..sad but true!
Enjoy it while you can nothing ever remains the same..
I have a set of Epos 14's in the loft...etc...etc
M. Gregg
