TDA7498 vs TDA 8920B KIT, need to make a decision now !
Hi !
Need your help in selecting an easy to assemble, affordable class D amp.
I already have a Yamaha AS500, LM3886 gainclone amps and would like to get a taste of a good class D sound !
Source: Windows 10 PC (Xonar DX)
Speakers: Magnat Monitor Supreme 3 way floor standers (5.6 ohm measured resistance), difficult to drive ?
Music Genre: Modern Rock at medium volume
Music signature needed: Bright, up front presentation
From where I can shop: ebay.in (also ebay.com with their global easy buy black friday offer)
Choices I have:
1. TDA 8920B
Class D Amplifier Using TDA8920 KIT Tone Control CRC PSU | eBay
2. TDA 7498 (YJ 32VDC 2.0 channel class D Parallel TDA7498 amplifier board 200W+200W better TA2024)
http://www.aliexpress.com/item/20-36VDC-TDA7498-parallel-2-0-amplifier-board-2-100W/1846481698.html
Not from Ali Express, but from an Indian FM.
3. Thats all I know. Please recommend any other kit from ebay to "research" !
Thanks in advance !!
The first two are Class D but at first look the LME49810 is a class A/B.
So the 8920 is a good amp but the TDA89XX series have high distortion at around 6KHz. Not ideal for hi go especially piano music. However the +/- power rails make using an opamp pre amp easy.
The TDA7498 is using a single supply and to me that is an issue but is you are driving from a PC that is OK. It is probably better sounding and more powerful than the 8920.
YMMV
YMMV
Thanks for the reply !
SO, I'm ruling out the TDA 8920B. (Its seller said me the same thing just now, its a bit noisy for hifi applications)
Then, its a fight between the LME49810 vs TDA7498 !!
And according to you, in terms of SQ, LME49810 is better ?
