Ok, got it, thanks!
What's the deal with Debian Stretch? Is it better than AudioLinux, Real Time?
It's just basic Linux. Audiolinux is optimized for audio. But for just straight NAA use from the command prompt, I'm not sure if there's any sonic benefit yet.
I asked Piero (the creator of Audiolinux) and he just said using Audiolinux for dedicated NAA use is like using a race car to drive the kids to school. Can't be bad, but used for the server OS, even greater benefits can be had.
If you read the Italian forum link I posted, Bibo tells you how to optimize the realtime extreme settings for when you are using Audiolinux on both the server and client with HQplayer/NAA. I haven't made it there yet.
This just may be the holy grail 🙂
After that next step, optical Ethernet isolation 🙂
Thanks Mike, much appreciated. A lesser man (like myself😀) would have jumped off the cliff rather than steel themselves numb until 43 emails before the penny dropped!
Following on, in other words if NAA is used it does not matter what OS is used at the client side, even Windows?
It sounds like lots of emails, but it was more of a flowing conversation. Most (or all) of the issues were due to my ignorance. 🙂
Another option - a good one in my view for a NAA on a fast network - is to do without a local drive and use LAN boot.No you need 16gb. I wish though. I'll be trying Debian Stretch running networkaudiod some time in the future though. It will fit.
Another option is to pop one of these Mini PCI-to dual micro SD or single full sized SD into the half sized PCI-E slot. This will make for a stealth install.
NAA Setup
I need help!
How to setup NAA?
I have two Win7 PCs, one with HQPlayer Desktop (server) and the other Client with Amanero connected and running NAA (just showing command prompt). On HQPlayer Server PC ->Setting->Backend:NAA but Tools menu -> "Network naming..." does not discover client, just blank window!
I can see and access the client computer via the server PC network so all appears connected
Have I missed anything?
I need help!
How to setup NAA?
Firstly, be sure that NAA sees your DAC through Amanero.I need help!
How to setup NAA?
Secondly, server and client must belong to the same domain. It's easy if you set a static IP address for both of them.
Thirdly, be sure there is no firewall enabled that prevents connection between PCs.
Your NAA/DAC must switched on first, then server.
If you still cannot connect, check your switch/router. Sometimes internet access is needed.
Thanks Bibo01,
I think I have got all covered except:
I am seeing a command window indicating NAA has launched. It does not seem to take keyboard inputs. So how now to check if Amanero is connect via NAA?
I would normally check with another media player like Foobar or JRiver that Amanero ASIO is seen.Thanks Bibo01,
On your server try to ping your NAA.
Ok, I will check with other media players. I can ping both ways Server/Client, even disabled Firewall. HQPlayer was restarted several times to sequence, even Pcs rebooted and did NAA first then HQplayer - still no luck!
A quick fix to these issues would be the Audiolinux image. Unless you value your time at about 25 cents an hour, it's worth the 29 euros in my experience 🙂.
Foobar on client can detect Amanero and play.
Maybe something weird going on. Client is a low-rent Tablet PC of yesteryear with Win7 32-bit. Thought this was good enough for NAA 🙁
Maybe something weird going on. Client is a low-rent Tablet PC of yesteryear with Win7 32-bit. Thought this was be good enough for NAA 🙁
Why not put the Audiolinux image on a stick and boot from it on that computer? I have it figured right out now, I can walk you through any issues. Forget Windows.
while waiting for the OS on stick to arrive.... Maybe I should just go for a pie and a pint to clear my head 😀
while waiting for the OS on stick to arrive.... Maybe I should just go for a pie and pint to clear my head 😀
Ha ha. You should have just downloaded the image instead. Much faster. USB sticks are a dime a dozen pretty much anywhere. You really only need the super fast sticks for server applications.
Maybe Piero would let you download the image in the meantime since you paid for it already anyways.
Try to test NAA on a different PC.Foobar on client can detect Amanero and play.
I am not sure Win 32-bit is a problem for NAD, but sometimes it is for HQPlayer.
If you can, try to use a different switch with internet access.
I have no other PCs, unfortunately except for heaps of winXPe 500MHz SBCs doing 'drone' stuff. I don't suppose these could do audio
Will see if I can grab from someone else.
I am using switch with internet access and all devices appear on the network and can ping one another.
But there were NAA installation options for x86 and x64 and I am running the x86 version on the client. So 32-bit must have been taken care of? Likewise Amanero installation on client is also 32-bit
Another question, since I am going to do DSD stuff then NAA must pick up ASIO drivers for Amanero on Win7. On the server side there is the control panel to select this if Amanero is connected directly but how would this happen on the client side? The NAA command window has no user input.
Acko, I think you need to take a break and listen to this. Unreal!!
http://youtu.be/EFDFpS9_ZWY
- Group Buys
- Direct Drive DSD
