Dynacord PowerMate 1600
I wonder if someone could help me with this problem of mine …
It`s about Dynacord Powermate 1600, there is unsoldered wire as you can see on pic, it`s a white thin wire with pink stripes … Enigma, where to solder it ???
Unfortunately I don`t have service manual … Everything else looks normal, power ok, just no sound … Thanks in advance ...
just so i understand your diagnosis of your trouble have you confirmed that the amp section is good as in no faults, output relay operates,no dc at the output etc.
and have you tested for signal through the input to the master?or checked if you have signal at aux outputs.
Update
And here is an update, audio goes thru mix to phones output, i assume that is no dc on out because relays are clicking and protections is off, but i have to check +-VCC ...
Here is another pic ... of a ,,strange,, wire ... 🙂
strange indeed it looks like it's going to an unused pin so why it was added is a mystery,
are we looking at the mixer out or power amp in? and with the wire being attached to one output i would think that the other should pass signal.
Thanks for your reply Zeon, here are some pics, just to see what is all about, on the board is written 5200 and 1943, is it possible to find them here ?
(I know this nick from some other forums here, Zeon is a ,,legend,,)
