dvv, I did not test any of my amps with DBT.
And yes, the sound of the amps as I write about them is just my say-so.
However, if you read my write-ups, I am very careful not to make subjective claims based on technical matters. So, like government, I keep 'church and state' completely separate. One issue is to do with the mind (technical) and the other with the heart (subjective). When the two disagree, only the judge (DBT) can settle it.
Andrew, I was not provoking anything, I am the man who wants to make his own sample of your amp. Obviously, I do not lack faith in your comments. I have trust in some say-sos. Occasionally, much more so than in DBT results. I have no trouble whatsoever that what you wrote was in good faith and that it is indeed so. My point was simply what you ackowledged yourself: sometimes, DBT is simply not felt to be necessary.
Same to you. Let's, happily, leave it here. I don't think we're as far apart philosophically as was being projected, unless you find Andrew's post between ours extremely objectionable. Even then, I'd still grab a beer with you at a pub and enjoy the conversation.
No, I do not, in fact I put my faith in Andrew's work to the point that I have started slowly gathering the bits and pieces for his preamp project. I'd hardly do that unless I trusted his integrity, right?
And yes, if that beer was changed into cider, I'd love to knock glasses with you. I am LONG beyond the point where disagreement on any single point is ever likely to be transferred to the person of the one I am disagreeing with. A bit too old for that, you know, 62 is 62, no matter what. By that age, one is expected to have gathtered at least some wisdom.
Human perception is largely a periodic updating of a model, with a huge amount of assumption, and correction to make it "seem" to be real time (it's not and can't be - latency minimum is at least .2 seconds, even in life-and-death situations). A good analogy is the way DVD video compression works.
Audio testing based on real-time or linear models is fraught with peril. Fraught, I say!
All good fortune,
Chris
Scott and Ed
The way I thought as a good one for estimating mechanic to electric efficiency gives plausible results with an MM but close to the edge with an MC cartridge. (Edit: The Eroica is with Neo magnets 😀)
With both cartridges, efficiency seems to peak with an ohmic load equal to the coil’s impedance.
At the recommended loading (47k for AT-110E, 100R for Eroica LX), efficiency seems to be close to 25%
I measured the cartridge output through an AD620 either as an x1 buffer or as a x53 flat preamp.
Good resolution and SNR with tone tracks was achieved by low resolution FFT (1024points) analysis of the recording. With higher resolution FFT, the problem of multi point peaks (it’s the medium) makes comparison btn different recordings difficult.
George
Hoping not to start up the firestorm again, can I point outn in ref to:
Just as classic THD measurement results are meaninful to those who need their instruments to tell them what they are hearing, while to me anything below 0.05% becomes essnetially meaningless.
Ive not heard of anyone in years (maybe since Julian Hirsch?) who said that THD indicates much about perceived sound quality. Mostly its a check that the builder didn't screw up on an individual box The quoted "0.05%" would put you far to the extreme within the "believing instruments" folks! No challenge, just saying.
I agree with your point: DBT is not always needed and as long as you enjoy the music and the sound, that's all that matters.
No firestorm from me: 0.05% (-66 dB) seems a safe enough low number. 🙂
So you are offering to fix this problem for free as its sooooo easy? Or do you in fact not understand how tricky this is.
Easy to answer-you:
Bestof-souvenir
70% of the code is mine. a lot of original tools, including an very nice upload tool for photos, entirely automatic, an exif/XMP viewer that exists nowhere else, a system of vote to populate the 'best-of' gallery automatically...
or have a look to Accueil, and see the galleries. Did-you ever had seen such a tool, both a slideshow and a lightbox in once ?
Now, you probably will propose yourself to teach-me Javascript, Php, CSS3 and html 5 ? It will be a lot of fun for me because it is obvious you don't have the slightest idea of what you are talking of..
Bill's Sousa demonstration validated my general lack of concern with ultra-low distortion, though it can be an interesting intellectual challenge to achieve it anyway. I can (and do) greatly admire the superb engineering evident in the Benchmark amp's performance while being cognizant that without peeking, people wouldn't be able to distinguish it from lesser amplifiers like Adcom or Parasound, or even my own little efforts.
Right--there are quite a few modestly priced (and suitably cheap on the used market!) amplifiers that are polite into impolite loads and push well below audibility. Comically mid-fi parts $$-wise where (most) sensible designers hang out.
But sometimes its just fun to read about the efforts/engineering of some to make amps that challenge outstrip distortion testing equipment. (Bucket list item for me post-defense)
That's why things like JCX's headphone amp (first one that came to mind) are awesome. It's utterly ridiculous in the best way possible. 🙂
Scott and Ed
George, it's been a while. I thought the conversation was about damping via motor assembly over a large range of frequencies. Like does driving a short do anything for a high frequency cantilever resonance.
Alternatively, Im pretty sure I could make an amp that measures 0.05% but that most would agree sounded terrible.
By:
A crossover notch-like distortion at very low level (tens or hundreds of mV) in a 200W amp and then measure the THD at full power like in most specs. As in Geddes' criteria of distortion products which increase rapidly as level decreases
