Article Wanted - "High Quality Amplifier with the 6AS7G" by McProud
Ex-Moderator
Joined 2011
The article appeared in the 1948 March issue of Audio Engineering, unfortunately, the copies found online are all missing the relevant pages, so if anyone has the complete article, could you please send me a copy?
TIA,
jaz
I was very satisfied with it's performance.
Attached the schematic, which is drawn with LTSpice, but the results given are measured values of the prototype without GNFB.
10 W @ 1 kHz with 0.25 % THD is a good value.
I also have LTSpice model if you need.
Pages 20-23 are missing from the scans but the complete article can be found in the (reprinted) AUDIO ANTHOLOGY Volume One (pages 5 to 8) and followed by a second 6AS7G amp ("General Purpose 6AS7G Amplifier", pages 10-14) also designed by C.G McProud. Should be floating somewhere on the web but If you can't find it I could scan the missing pages from the original book I own.
1949 articles by McProud.
As I use lots of those in OTL amps I'm quite familiar with this tube and absolutely love it.
It's low anode impedance relaxes the demand on the OTP so you can expect excellent bass and highs.
Of the lot I prefer the sound of the 6080 over the NOS 6AS7G with the possible exception of Sovtek's version which sounds much like the 6080.
One little amp that sounds quite impressive on high efficiency systyems (a la Lowther etc) is the Italian Triodino. I think it was using ITA Megaherz iron.
Cheers, 😉
