I'm more busy these last days that I was expecting, so here's a few photos of the PCB. I have started construction, but not to a point where I have anything useful to share. Hang in there.
What size will the final board be? It's an all-in-one: 1 board for ps and 2 channels right?
Hi All,
a friend of mine build a nice pot with Muses 72320, hope to implement it here . So, how long we must wait for pcb?
Nice features, remote and display.
In german D..... says:
- 35x35mm
- 2,4,6,8 Kanal da Muses Boards kaskadiert werden können. Man steckt hinterm Controller einfach mehrere Muses 2 Kanal Boards
- 0dB to -111.5dB/0.25dB und Mute
- 20kOhm Eingangsimpendanz
- Bedienung / Befestigung über Drehencoder mit Tastfunktion
- Abspeichern aktueller Lautstärke als Startlautstärke
- +/- 15V Spannungsversorgung
- Controller wird bei "nicht Bedienung" lahmgelegt, d.h. alle Takte aus, um Störungen im Audiosignal zu vermeiden
- Lautstärke +/- und Mute fernbedienbar (RC5, RC6, NEC, Apple...) inkl. Lernfunktion
- UART / RS232 Ausgabe (empfangene Fernbedienungskommandos, allg. Infos)
- zukünftige Erweiterungsmöglichkeit um Anzeige oder Relaisansteuerung (7-Segment etc.) über weiteres aufsteckbares Board
- 35x35mm
Very nicely done Muse's board!
Is it better to use a digital volume control chip or a digital pot chip (like a TI TPL0102 or TPL0202)? Or is that too general a question?
-2,4,6,8 channels as the Muses boards can be stacked/added. Several 2-channel Muses boards can be hooked up on/behind the controller.
-20k input impedance
-adjustment/mounting by rotary switch/encoder (with manual operation)
-possibility to lock/store the current volume setting as the start-up volume.
- +/-15V operation voltage
-controller is turned-off when not in operation, aka all contacts-off, to avoid disturbance of the audio signal.
- volume +/- and mute function remote-operated, including learning function.
-UART/RS232 output (received RC commands, general info)
-future expansion possibilities for a/the display (7-segment) or relais-control on another connectable board
Well they are pretty much the same some just have more circuitry. The Muse and the Maxim1882 are two I have used successfully. The board is set up to use the Alps 27 Mm pot.
Except there is a huge difference in price - <$2 for the maxim, $20 for the muse. Similar for TI parts iirc. I don't want to take this too far off topic, maybe I'll start another thread.
Thank you
It is my work
There is also a implemantation for 7 Segment Display from adafruit...
Thank you
It is my work
Very nicely done
Are you going to offer it as a group buy or something?
I'm sure there would be interest.
A new thread on this would be nice.
Randy
- New PassDIY Headphone Amp (now available)
