Yet another DIY AMT
So finally I managed to get a second membrane ready and mounted in the right speaker.
Measurement from 50 cm, 1/6 octave smoothing:
L7WrxKDfjUjtgY8mxCx7Z-5e86z6B3SRfER1MIt3Gpss=s800
I changed the PEQ to 4800 Hz, - 4 dB.
I think I now got a good concept with the motor.
The wave guide and most of all the membrane could be improved a lot though.
Especially the folding tool need a complete overhauled.
Looking really good! I'd love to see some measurements of CSD and impulse response. Areas that a AMT should excell in.
/Anton
I've tried get a CSD, but the resolution wasn't good enough. But perhaps it was SBS.
I also think that my room isn't quiet enough to do proper impulse response measurement. Anyway, here's the impulse response from the measurements above:
iGgstcnax0q3I3bFLCSUZonA8_WZ17t0lqbhLFvuLvZz=s800
Looks like it's inverted. Can you zoom in on the first 2 m?
Oh, and do you have the phase? Should be possible to get an accurate reading from below 1 kHz with some windowing.
/Anton
I will exhibit my setup at a small DIY gathering in Jönköping, Sweden, the 24th of October.
Practically, only Swedes will have the possibility though.
The new AMT was highly appreciated and I am now convinced that this design is the one to evolve further.
A better folding tool and a better wave guide are candidates for improvements but also the motor can be enhanced; perhaps have the front pole pieces as thin as the back pole pieces.
But then I will have to figure out how to get 64 pieces of N42 neos hold together, right now it is the front pole pieces that holds the motor together.
Thinking of scrapping the wave guide and instead go for the full monty, an AMT line array:
Two TD15H in the bottom and a 120 cm high AMT Mk IIB in the top.
Total height will be 170 cm. Three or four AMT membranes.
