Boost Converter w/ positive AND negative output
If anybody has bought such a HV boost converter (or similar from other vendors) or knows the answer:
High Voltage DC DC Boost Converter 8 32V to 45V 390V ZVS Capacitor Charging free shipping -in Integrated Circuits from Electronic Components & Supplies on Aliexpress.com | Alibaba Group
What puzzles me about the +/- output version:
- how can a non-isolated boost converter produce both, a positive AND a negative voltage ?
- boost has only an inductor and can only boost one polarity !
- unless it is actually a flyback with transformer secondary center tapped ...
- but then, why non-isolated ?
why don't you buy one and reverse engineer it?
i suspect flyback and the controller tied to one half of the bifilar secondary's makes it DC-DC
good luck finding the controller #, somebody said they sanded the tops.
I would subscribe to your findings.
As requested.
You can check the high resolution pics by clicking the images below.
I happen to have a pair of this module so i posted a picture with them mirrored.
http://minus.com/i/LcmWN7d9pNyf
http://minus.com/i/mm7DzvLT1ldD
Yes, the controller ID has been sanded-off. The secondary winding seems centertapped with each end connected half wave rectified by ultra fast diode. One end makes the positive and the other end makes the negative, hence bipolar.
Unfortunately i don't know enough about SMPS to comment more. I do agree it seems this is flyback type. One end of the primary winding goes to the center pin of the heatsinked MOSFET.
I will be bringing this module with me for the week, so if you have any more question, i can help to check it. Do share any findings.
I have only a pocket oscope.. the DSO203 Quad.. Do you think it's precise enough to see the output of an SMPS?
DSO Quad - Wiki
Can you tell me what is wrong with ZVS capacitor charger circuit? Low switching frequency?
IDK I guess it works fine if your building an electric fence of or a zapper thingy.
your 'scope' is not a tool id pick to characterize HV SMPS, it could be used but would take advanced thoughts of what to look for! a double minus for most DIY folks I reckon. some models are limited to 60V.
OTOH for audio if you cant hear it nor see it, it'll do, if it causes grief, it might take some more work and $
@ballpencil: thanks for the pictures;
I'm pretty shure now it's flyback; ct of secondary connected to gnd of input for easy regulation feedback (isolation would require opto-coupler for fb)
btw there is also a single voltage version available from multiple vendors, some as low as $7.
