System Pictures & Description
Part 1 My interpretation of Yuichi 480 horn and bass cabinet.
This is my first attempt at anything horny.
I used copper for the horn cut from 4" type b copper (nice and thick), annealed copper and beaten into shape. Used lead for the fins, made a mould and smelted.
Colourised the throat with any oxy torch to get different colours, (not very good at it,) then used pouring epoxy to keep the colour and make it shinny. The out side was left as is.
Reactions: CLS
Part 21 My interpretation of Yuichi 480 horn and bass cabinet.
Second stage was the cab, had a rough idea of the shape and went along with it
Was using Eminence Kappalite 3012lf http://www.parts-exp...97zb000bib0005c
In a mid sized vented cabinet of about 50ltrs.
Used 16mm MDF and cladded it with a mixture of 7mm x 70mm Merbau slats and pine.
Kerfed the rounded bits (what a bugger to do)
All joints were rebated for strengthening.
Top and bottom compartments were braced.
Bracing behind the driver.
Filled the bottom compartment with dry river sand.
Painted internals with tar paint.
Part 3 final My interpretation of Yuichi 480 horn and bass cabinet.
Made a base, attached the horn installed the drivers.
faitalpro hf 10ak http://www.parts-exp...-bolt--294-1011
Mixed up some Shellac and gave it dozen or more coats.
Made a cover for the eminence drivers.
Made some wires
All done (except still working on the minidsp), kindly modeled by Jasper.
