Crossover Design Contest! Win Prizes! Active or Passive! Entries due by OCT 9th.
Announcing the 2015 Burning Amp International Loudspeaker Crossover Design Contest!
Your goal is to design a passive or active crossover for a 2-way mini-monitor using any freeware design software. The winning design will be awarded the drivers and cabinet for the project - design the best crossover and win the parts to build the system!
Even if you don't plan to attend Burning Amp this year you can still enter to win. Just pair up with someone who will attend Burning Amp and submit an entry as a team! You can prove yourself as a crossover WORLD CHAMPION designer!
The deadline for submission of entries is 9pm Pacific Time on Oct 9, 2015.
To download a complete set of measurements and see a list of contest rules please visit:
2015 Burning Amp crossover design contest!
Hi Charlie,
so, if I understood correctly, I can submit an entry with
my internet pseudonym, my e-mail address and appoint
one person (real name) to collect the prizes at the BA
festival in case we win as a team?
Hi Charlie,
Yes you are correct. The team concept allows more people to join in on the fun! As long as someone from the "team" can physically attend Burning Amp and collect the prizes, anyone anywhere in the world can submit an entry as part of a team.
Of course if you can attend Burning Amp personally and want to submit your own entry, that is also totally fine. It is not necessary to form a team in order to enter the design contest.
Rules Clarification
Below is a clarification of the contest rules:
  • There is NO REQUIREMENT to be present at Burning Amp. You can still submit an entry (and win or place) if you don't attend.
  • You can NOT collect the prizes if you or someone from your team does not attend Burning Amp.
If you are willing to forfeit the prizes and want to submit an entry just for the fun of it, you are more than welcome to do so!
How are the submissions going to be judged ?
Its not stated in the rules ....
rgds, sreten.
Since this is the first year for this contest, and since it was just thrown together in the last few days, we are figuring out some of the details as we go along. I don't expect that details about the judging criteria will be posted. But generally you want to aim for a flat on-axis response with good phase alignment at the crossover point. Additional info about the off-axis response of the drivers, and their distortion profiles, has been provided to help guide the designer.
I do not plan to participate in the contest, but I noticed that XSim does not accept the provided zma files (error message). Attached is a corrected version of both files that should load easily.
Good luck to all the contributors.🙂
Thanks for posting this. I compared the two files in my favorite editor (PSpad) and the only difference is at the end of the file. The ZMA file I supplied has two entries for 20kHz. In your file these have been removed. Otherwise they are identical.
I will let others know that they can just delete one or both 20kHz entries to fix the problem.
I found another error in the woofer impedance file - some "negative" signs somehow became separated from their numbers, e.g. "- 1.2345" instead of "-1.2345". This happened for the data between about 70Hz and 210Hz in the woofer file only.
I posted another updated data set, with "update-2" as part of the file name. Please let me know if there are any further import problems.
Would an elegant passive design beat a complicated active design if they both achieve similar goals? Will passive XO parts also be provided to the winning entry or just drivers and box?
The crossovers are simply judged on what they achieve in terms of the loudspeaker. There is no rule limiting the complexity or cost of the design. I believe the only limitation is that FIR filters are not allowed for DSP crossovers.
The prizes are clearly stated in the contest web page and don't include any crossover parts. There is no way to know at this time if the winning entry will be a passive crossover.
I'd like to take a stab at it, just for fun. I know it is possible to get the time off-set between the drivers based on the unfiltered combined response you included, but it's a hassle and not the most accurate. I assume you performed 2-channel measurements? Would you please post the PIR files?
Why are FIR filters not being allowed?
PID files are not available. I didn't save them.
I use the interference method all the time to determine offset and it is not only quick and easy but very accurate as well.
