The diyAudio Firstwatt F6
Nelson says it better than I do. Here's a paragraph from the F6 DIY article from 6moons (R13 & R14 = R1 & R2 on the Mosfet schematic). Just wondering if there's a value with the Mosfets under which it isn't recommended to go. 😱
If you are interested in adjusting the harmonic structure in this amplifier, there is a nice easy place where you can do it. I have added low-value power resistors (R13 and R14) in series with the Source pins of the output transistors. Typical values for these would be 0.025Ω to 0.1Ω. If you leave R13 at 0Ω and put 0.05Ω for R14, you will find yourself with a positive-phase second harmonic. By this I mean there will be expansion as the wave goes positive and compression as the wave goes negative. If you have a negative-phase second harmonic, you could use this approach to null it out. If you leave R14 at 0Ω but set R13 at a small value, you do the opposite either creating a negative-phase second harmonic or nulling an existing positive-phase second harmonic.
Yeah. There certainly is. Going where no man fears tread is what a FAB is about.
When he wrote that article he was referring to semisouth devices with much friendly temperature coefficients.
I built an F5 with no current limiting circuit or thermistor to control bias and the bias certainly does want to creap up in value. Setting the bias was a slow process. That was using 0.47 ohm source resistors on irfp240/9240
I'd take a guess and say 0.3 ohms might be achievable with irfp240/9240, but wouldn't bet my house on it till I had actually tried it.
So would setting those resistors too low result in thermal runaway or something more catastrophic? Basically would some thermal sensors which trip a relay controlling power prevent catastrophic failure if one wanted to experiment with different values?
Forget over engineering and controlling everything.
Just experiment to find what's safe.
Nelson might provide some further advice but there's nothing stopping anyone doing their own tests. That's what its about. It doesn't take long to swap in and out different source resistors.
I know this has been covered, but I can't find the info I'm after.
I know NP posted a thread about this, just can't find it at present.
Transistor insulators.
I know mica is much preferred, But I'm having trouble finding any in the to-247/to-3p size.
Mica ~ 0.7wm/k
I can however get these
Aluminium oxide 15.06 W/mK @ 75° (solid pad)
Thermalsil III 0.92 w/m °C (silpad)
Thermalfilm™MT 0.379Wm/K (kapton)
Would that not mean the aluminum oxide is far superior ?
Second choice, thermasil or thermafilm ? noting there rated as celcius or kelvin, does that make a difference overall ??
Thanks..
Mica ~ 0.7wm/k
Thanks..
If you don't need many just get keratherm pads from diyaudio store.
