Global Feedback - A huge benefit for audio
Not to make too fine a point of it Bill, but I did present a known method for dealing with that. You went out of your way to attempt to take me to task on it as well. Remember?
Yes you were off on one with your 'power paradigm' which made it very difficult to take you seriously.
Anyone who thinks they have flat frequency response is also fooling themselves. Just take a look at driver response and you will see what I mean. Amplifiers aren't the problem- speakers are. They are all over the place for FR. So if you like any particular given speaker because of something it does, the chances are better than not that it has some interaction with your room that you find pleasant. One thing is certain: its not flat FR. Run a pink noise test sometime...
MiniDSP. Marvellous device and really winds up the luddites. WNTL? 😀
Age And Listening
Question for folk. How do you deal with how things sound as you age?
I know that today (age 70) what I hear is quite different from what my hearing was like 30 years ago. Tinnitus, hearing loss, etc. now are the way it is. As a result, the sound I like has changed. Does this mean my amplifier, designed by listening, will be significantly different today than 30 years ago? No axe to grind, just curious how age has affected what you hear and how it affects your preferences.
Bill
Anyone recall motional feedback where the speaker was either acoustically or mechanically included in the overall negative feedback. Was that not the correct approach, maybe before its time?
Yes, the concept is still alive an in use. But it works well only at lower frequencies (cone resonances make the loop very difficult to keep stabilized) and the amount of feedback that can be applied while remaining stable is rather low. Usually practical (as opposed to short-term in lab conditions) harmonic distortion improvement isn't very large because of the low loop gain as frequency increases. The main advantage is that compression at low fundamental frequencies is reduced.
🙂 I've never met anyone who was truly objectivist in their approach to audio. Never heard of anyone either. IME anyone who says they are is fooling themselves.
?? never experienced that...
I find that the recording has more to do with it, and as a string bass player I can't get the bass to sound right if the damping factor is too high.
It can but does not have to.
Yes, but a clean, flat signal from amp makes it a lot easier to deal with speaker anomalies.
Clean flat amplification is a commodity these days, thanks to GNFB. The same cannot be said of clean, flat speakers, (and listening spaces).
I've found reducing the no. of variables I've got to deal with is a Good Thing. [edit] Folk can always dial up some colour they'll allow themselves some EQ.
so call it current drive like every body else does? Nothing new.
So you really didn't follow along! Yes, it's nothing new as I said before, but it's not current drive. Current drive is where the amplifier has an output impedance significantly higher than that of the load. To do this current feedback is often employed.
Power drive OTOH is where the amplifier output impedance is near the same impedance or slightly lower than that of the load. Either no feedback is employed or else current and voltage feedback are used in nearly equal amounts.
:up:
And speakers, and the understanding of their interaction with rooms, are getting a lot better these days.
:up:
Yeah. For more than 20 years I've been thinking the low hanging audio fruit is speakers. But, only if my psychoacoustic knowledge/understanding can be adequate. With regard to the latter, I have to say when I first started looking in this direction, that an awful lot of useful knowledge had only just been found out and a great deal of good research was just getting underway.
Toole's big book is remarkably useful for a critical reader. Huge info mine.
Funny how we hear different. I never could get bass sound right until I went active with high(ish) DF amps. Friend of mine is a professional bass player (electric and acoustic) and he checks everything he records on my stereo as it has, in his words, the most realistic bass representation he has come across.
That's really true. The room dictates all we hear, nothing new... Measurements and calibration systems, IMHO, are far from giving us the real sound that we hear, but yes, thats what we have, so we have to count with it.
I have some experience with Dirac software, and it's far away of what I think to be a good audio reproduction, it's called Dirac Live, a digital room correction system. To me it sounds like there is a funnel between the speakers and all the instruments are there. The "target curve" you make of your system is very beautiful, but the result is not for me.
room correction
Room correction can help at low frequencies, as can carefully-placed multiple subwoofers. Otherwise they are fashionable but not particularly useful, and some are downright awful. As Toole's paper referenced above begins, it has long been thought that a single microphone measurement of a steady-state amplitude response is an important indicator of how a system will sound (paraphrasing there).
It's not. As FT adds, "It is an enticing marketing story".
If the speaker is designed to use a higher Source impedance, then the user manual should state so and explain how to achieve the effect that the Speaker Designer intended.
It is not the fault of the amplifier, nor the amplifier Designer, that a speaker does not perform as intended when it is designed to suit a higher source impedance.
Much has to do with whether the speaker is designed for high DF or not.
If yes, the FR will suffer. If not, the FR might be just fine.
I was thinking about thd fft, not FR:
compare thd fft resistive load vs real speaker.
if there will be more hf fft peaks with real speaker that means that its coil acts like microphone injecting additional signals to gnfb loop
which should not occure with low df amp
