from DIY Indonesian Amplifier
from legend amplifier in my country,,😀
Ah, it's Bimo, an active member of this site. I knew it, because there is no solid state amplifier expert in my country 😀
It's a simulated distortion. There is NO way the real performance can reach that, with such bootstrapped LIN topology.
Hi hajidian,
Yup, not that design. The distortion figures have waaaay too many figures after the decimal point. Readings are always noisy and you can't measure to that level of accuracy.
One very helpful improvement might be to regulate the power supply rails for the voltage amplifier stage. You will gain s/n ratio and freedom from the heavy currents of the output stage to affect the voltage amplifier stage. Break it at the 100 ohm resistor + diode point and feed the front end from there.
Your performance will depend greatly on how closely you match the input pairs (2SC1845) and how closely they are tied together to maintain the same temperature. There is no reason why it won't sound very good if you follow those points.
How hard are you going to run this amplifier? If you are going for high power, the drivers should be beefed up, or even make the output stage a triple. Amplifiers don't usually "scale up" to higher power without some more changes.
-Chris
Hi, this is my design 😀
I want to make amplifier as simple as possible and enough power. I choose double emitter follower because it simple but if use high power supply and low impedance load (below 4 Ohm), THD will be too high. So, this is my compromised.
You can not use it for 2 Ohm speaker, unless you change output stage to triple emitter follower and add more output transistors. It tested by one of my friend. In first version, the current for LED is too small then he increase power supply to +-70VDC. It stable and sound good according him 😎 The second version, I increase LED current. It should be stable for +-63VDC power supply.
Hi bimo,
What power levels are you hoping to run at? All I know is that with that many output transistors, the poor little 2SC4793 / 2SA1837 will die first during a current spike into the load. Some 4 ohm speakers have a nasty impedance curve.
What do you think about running the voltage amp stage from clean power (ie regulated)?
-Chris
Hi bimo,
-Chris
what do you think about this amp.. can you give me any sugestion?
regards:cheers:
Hi hajidian,
The amplifier is a basically good design. I just had a couple of questions, that's all. I would let bimo answer first before deciding anything. Besides, we still don't know how much power you are wanting out of this amplifier.
-Chris
Hi bimo,
-Chris
2SC4793 / 2SA1837 capable to drive 350W/4 Ohm. For pure 2 Ohm load (non inductive) those driver transistors still within their SOA. But of course MJE15032/33 is better but expensive.
Hi bimo,
Please say hello to Hugh for me.
If using MJE15032/33, C lead must be increase to 10pF to maintain the phase margin.
That is the road I would recommend. By comparison, how much more expensive would the ON Semi parts be. He is only making his own amplifier, so the difference in price on the entire project wouldn't be that much.
I use the 2SC4793 and 2SA1837 myself. I have a bunch of them, but I would still use the heavier drivers for this project.
Cheers! -Chris
