"What window function did you use?"
Hi SY,
Sorry, I should have said. I copied your settings except that the Transit only operates up to 48KHz in ARTA. I didn't save the original measurement, so I re-did the test as shown attached via a print screen capture.
Peter
Hi SY,
Peter
Same test conditions as yours but using the Focusrite Scarlett 2i2.
I've missed the post about how this test is done and what it means... since that is my soundcard, I'm interested in whether that's good, bad or indifferent Also saves me doing the test myself
Tony.
Distortion goes through the roof.... noise floor may also suffer but I can't remember.
It doesn't have dedicated se outputs. You just put in a tr plug instead of a trs and it suffers.
edit: attached some measurements I did a while back... 3rd harmonic in the balanced isn't fantastic either, but I guess a notch in the buffer I'm thinking about might help there...
Tony.
Tony.
^ Yes, and I might look at doing something a little different with the output using a trs plug and then a resistor to ground for the ring to sleeve connection to see if that helps. but the 2i2 manual clearly states that either balanced or unbalanced 1/4 inch plugs may be used
Tony.
Tony.
Peter,
I'm interested in your ARTA Transit calibration settings. How did you arrive at 2710.95 for line-in sensitivity? That corresponds to 1.9VRMS, which is well above the ADC clipping point of the Transit. (For reference, I use 1920.00 on mine.)
Dave.
Hi Davey,
I'm not sure where that 2710.95mVpk line-input sensitivity came from. I suspect that it came from one of my other USB sound cards such as my E-MU 0202. As it turns out it does not seem to matter, because when I go through the cal procedure for the Transit and re-test the jitter, it gives the same performance as before. I suspect that if Ivo outputs a -10dBFS (for example) he will be able to check the level that appears at the ADC output on a loop test and adjusts the levels accordingly, but I have no proof of this of course, just my guess as to what he does in software.
Peter
Has anyone here tested the M-Audio M Track Plus II?? M-Audio - M-Track Plus II
M-Audio has been bought and sold a couple of times over the last few years. I wonder if the quality of their current stuff is as good as their older products.
