amplifier transistor problem
Its possible to replace the FET's in your amp with BJT's .....
I need to see the schematic....
Need to modify the biasing arrangement to accommodate the Base current...
Also need to re-configure the voltage the current division of the driver stage....
The question is if it's worth the hassle ???
In my amp ?
No, its designed exclusively for laterals and would need a redesign of the driver stages to use bjt's as well as incorporation of a vbe multiplier of some sort for biasing and thermal stability.
