TPS7A4001 vs Salas shunt Reg
@ K i n g P i n: I have received a couple of the PCBs, shown in image 1, some days ago.
The results that you have published, look very promising !
But: I will never be able to solder the TPS7A470x - regulator in its QFN package. I do not have the means to do this!
I do not dare to ask Ales (mravlca) to solder the TPS7A470x on the few couple of PCBs that I have, since I do not want to compete with his offers in this forum, ebay, ...
Ales: be sure that I will not offer the shown PCB in this forum!
But, to go on with my own needs: I did a nice (?) layout of a symmetric LT1763 - LDO - regulator (image2) and wonder , if it will do a nice job as well!
Best regards - Rudi_Ratlos
P.S.: @ K i n g P i n: I have just sent you a PM.
P.P.S.: I did not notice until now:K I N G P I N: you are using Ales' PCBs!
Ales: thank you very much for your kind offer! I will take it - for a very few PCBs only.
As you know, I am not able to "measure" the performance of the PSUs that I have, but maybe that I will "hear" some differences.
From left to right, see images below:
1) SALAS Shunt Reg
2) TPS7A4700 based PSU
3) LT1763 based PSU
I will connect the TPS7A4700- and the LT1763 - PSUs to SALAS' "Hypnotize Pass-B1-Buffer and will tell you (compare) the differences that I hear (if any).
But this will of course take some time!
1) SALAS Shunt Reg
3) LT1763 based PSU
so any updates we are very eager on the results on aural comparison.
rhythmsandy
It's no use ... Look at the date, no one here is almost half a year. It seems that then Rudi_Ratlos [/ B] went wrong ... He finished 20th August 2015 the assembly of test specimens and even managed to put pictures ... I wonder which of the samples happened to him this misfortune? But as the other participants in the conversation, I was hooked speculated
Sorry for my bad english
rhythmsandy: I am sorry that I did post the result of my comparision.
I have indeed tested the Pass B1-buffer being operated from 3 different PSUs:
- from a SALAS shunt regulator on his "simplistic B1-buffer" PCB
- from a dual LT1763 PSU operating my RPRE - B1-buffer (image 1)
- from a dual TPS7A4700 PSU operating my RPRE - B1-buffer (image 2)
Even though the output of the SALAS buffer looked very good on the oscilloscope, I was not able to listen to it, because my setup is producing a much too big volume.
It is not able to play quietly. This is of course a problem that I have caused myself, but I did not yet find the solution for it.
Concerning the LT1763 vs. TPS7A4700: both PSU regulators produce a very low ripple current (30-40µV vs. <10µV) and have an excellent load and line regulation.
I do not "hear" any difference.
But since the TPS7A4700 is near to impossible to solder, I will stick to the dual LT1763 version.
dual LT1763 version what you mean by that?
Fillipowich,
Dual-LT1763-PSU means: putting two LT1763-based PSUs on a single PCB (size of which is 50 x 100mm).
You can either configure the outputs as two separate +VDC outputs or - by putting a cap on jumper JP1 in case you are using a transformer with two separate secondaries - you can configure it as +/- VDC outputs.
I - for example - need a +/-10VDC PSU to operate my Pass B1-buffer.
