The diyAudio Firstwatt F6
I went with 0.62 ohm and it sounds fine. CL6 suggested to me to use 0.56 wirewound and if I am correct that is what he used. I have since used resistor in parallel formula with my 0.62 to bring it down to 0.55 and I did not notice any difference in the sound to my ears. When I make a new order I will purchase a wire wound 0.56 ohm and may replace my 0.62 just because that is what NP describes.
As far as I can tell, the 0.56R resistor is there to shape the sound - it's causes a slight difference in 2nd harmonic.
There's no question that the amp will operate properly and sound great with 0.47R in both source resistors.
Hi guys, I recently started building an F6 pretty much from scratch. I made my own PCBs and stuff rather than using the ones in the DIY store. I just have a couple questions before proceeding with placing the parts:
In the (incomplete) F6 build guide a 9.1V zener diode and 110Ohm resistors in place of the 47Ohm R11/R12 from the schematic. Would you recommend that i proceed with the values used in the guide or the schematic? Does it matter?
Also, when I first apply power does the pot need to be set to a certain position to avoid damage to components?
Considering I built the PCB myself I want to be very careful not to damage any components if there is a problem..
This is the first time I've built an amp like this so i am kinda new to this.. If you have any other recommendations I would really appreciate it.
Hi Forum,
I've been wondering for a few days about the following:
Is it possible to build an F6 using P-channel devices (e.g. IRF9240)? I understand that some rewiring must be necessary, but is it possible? And would there be any obvious drawbacks? Have anyone tried? Should I try?
Hi Forum,
Yes, just reverse the power supply polarities, the zener bias polarities, and the electrolytic cap polarities. Flip the input buffer supply connections so the top one still goes to the + supply.
Here's a picture of the board I made..
Does anyone happen to understand why R11, 12 are 110ohm in the build guide while the original schematic uses 47ohm (I think he used a 9.1V zener instead of the 5.1V in schematic, as well?)
I've read through quite a bit of this thread and I can't seem to find an explanation so if there already is one I apologize, just please point me in the right direction. I am actually placing the components right now so I need to make a decision before I proceed.
The original F6 had those Semisouth power Jfets. Those did not require much voltage to get going. This diy version uses the good ol' IRFP240 mosfets which requires more oomph. Bigger gatestoppers just make for a better behaved amp, less likely to suffer parasitic oscillation.
