Photo Gallery
Preamp with tube regulated power supply, baxandall tone controls and 40Hz 18db/oct tube subwoofer crossover.
2ch pushpull power amp.
ub+ 500V ~80W/ch
Monoblock plays subwoofers.
Parallel push pull, 6x KT88 ub+ 520Vdc
Very nice!
Thanks. Here are a couple more pictures of the preamp. The markings on the fascia are etched with the saline sulfate method. This etch didn't turn out quite perfect, I slightly overetched it, but it's good enough. The etchings on the poweramp turned out better. Still some practice needed to really master the method.
Adolf,
I would like teh volume knob to be more modern and minimalistic. The vintage one spoils the excellent design.
Everybody's a critic ;-) I get their criticisms. I don't think though you are trying to fool anyone. It's a modern-day piece using vintage glass; it's your take.
I hope it sounds wonderful!
If You don't hear a difference with fans on or off, use them to make things cooler and last longer.
Cheers!
The end justifies the means. I do not think that there is a strong heat. tube modulator is not a radio station. the picture of retro lamps with low power consumption. and fan and lamp things are not compatible
Who can say anything?
Who can establish styles?
These are our things. I like very much blue valves with fan behind.
You can ask something of your curiosity but not criticized any.
I do not know English. I use a translator .A he roughly translated. I do not critique suggests. . I just expressed my opinion ..u I had a negative experience with the fans.It was heard in acoustics. in this forum, you can express your opinion ?. and to take it or not is a personal matter. because you have democracy?I liked the design. I wrote about this in the message №6708. good luck
My UL SE EL84
My UL SE EL84 FUNKWERK Germany and pre E80CC TUNGSRAM, built in San Diego. OTs and PT are from EDCOR USA. Outpower is about 2 x 4 W for 8 ohm. /Sorry for turned and bad photos from my cellphone.....I can't manage with it and my tablet/. Amp can be for sale...for about part's price...if someone interest.
Car audio amp
Completed this a couple of weeks ago. Took about two months building it in my spare time. Uses two KT88 tubes for 22W out. Sub chassis is 1/4" aluminum covered with 1/4" purple heart wood and topped off with 3/8" copper square stock. Sounds wonderful.
