Scrape flutter is real. Some tape playback systems have less, depending on the addition of precision rollers added to the tape path.
Yes, it is! Even my homebrew tape deck has such a roller:
Edit: Actually, there are two of them: one more between the recording and playback head, though much smaller.
Cheers, E.
Keantoken, you may want to compare BC32xx with BC547/557. They are typically rated as "B" gain class, but they often have a gain of 400:1. On occasion, they and BC550/560 low noise types are offered with a "C" rating, but that needs luck to be found. Do try at buerklin.com, they are not cheap but are reliable, been buying from them since 1975.
BC547/557/550/560 are all currently available at Mouser in C grade.
Tape binder was often responsible for tape scrape noise. It was an FM modulation (very physical) created mechanically. As a side note, Agfa could make almost any machine squeal, Studers included. The residue was not visible under normal viewing, but Methyl Hydrate would clean this off. Probably Ampex head cleaner would as well, nasty stuff!
Those rollers you are referring to were called impedance rollers by Studer and by some at Tascam. I worked with the studio tech at The Metalworks for a bit. Incidentally, Dave built a tape baker that would reset the binder allowing you to get at least one play out of old masters. The idea was that you dubbed the old master onto fresh stock in a one shot deal. I do know they rented that oven out to other studios. Apparently it really worked.
-Chris
We used it for decades in the film industry. Nagra recorders would often have a 60Hz control tone.
The 60Hz freq stability is +/- 0.1% from the massive generators at hover dam. I think that is short term. Long term average freq stability with constant correction should be much better.
Our ac powered wall clocks depended on the 60Hz accuracy.
THx-RNMarsh
The hum thing in isolation seems just too easy.
Yes...looking a bit more into it, it seems the use of 60hz-hum may have been one of several backup techniques used when the bias signal was unrecoverable. But I'm not sure. It's hard to extract the technical details from the popularized accounts that resulted from Kevin Short's grammy win victory-lap/PR-tour. Short only seems to talk about using the power-line noise for reconstruction [page][mp3 2:15-3:05] , but maybe that's because he worked on that part.
The detailed answer is supposedly in the 72-page book that comes with the album. I don't have the album or book. I've only found these comments which summarize:
as is apparently the case with most wire recordings, had some amount of speed instability and "wow". Jamie Horvath and Dr Kevin Short were able to correct much of the instability by using remnants of power-line hum and record bias as well as noise modulation and the guitar strings as a reference. Finally, Steve Rosenthal mastered the result using a Cedar Cambridge workstation to de-hiss and de-crackle, Massenberg analog EQ and a Chandler "Abbey Road" compressor.
If it started with a wire recorder there would be no RF bias. RF bias was not introduced until later. There may have been a DC bias which would raise the noise floor.
Film recording used a 60 Hz sync track which was then used to drive the syncro motors in the dubbers to transfer to mag film. Given the difficulty in getting a stable precise motion for film and tape in the 50". 60" and 70's it worked quite well but was big and clumsy and mostly passed with digital recording and widespread use of small crystal oscillators. The Nagra used a second stereo head to record the track over the full track mono in a way that would cancel on playback except with the matching head.
20th century ..
I'm starting with PPM source , amplifying with PPM silicon.
Then I end up with the mess that my physical drivers (loudspeaker) make of this
perfection.What am I missing ?
Subjectively , I'm listening to 200W aggressive rock now , the amplification
is absolutely stellar. What could the guru add to this ?
Could he give me a source that would make my -200w more stellar ?
PS - I'm PC- DAC - 200W amp - straight shot !!)
OS
