A power amplifier with 2SC2922SA1216
I happens to have some of this power trans and transformer that gives me 2x54V DC. Can anyone "come up" with a DIY project that includs a PCB (to copy or to buy) that "suits" this components??
Eivind Stillingen
How many do you have ? 2 pair each (8 total) would have a 200 watt amp.
Try this group buy. -http://www.diyaudio.com/forums/group-buys/257057-slewmaster-project-boards-7.html
If he has gone through all these boards - I'm upgrading to the board on the
above link - my present boards will take 6 of those sankens as a very
powerful 300W class AB amp - I'll sell them cheap.
These "slewmasters" are about the only forum kit especially suited for
the MT-200's. A much more refined project than any Ebay offering.
BTW , this is a output stage/ input stage modular project ... you get
to choose just about any forum amp (sansui , sony , adcom type input stages).
OS
stocktrader200
I will go for a Honey Bader.PCB already ordered. Did you do any changes from the original when you used 2SC2922SA1216? I will connect the output using wires because of the heatsinks that I already have. Any problems with this mounting of the devices?
Eivind Stillingen
stocktrader200
Eivind Stillingen
I already did the preliminary on a badger - mt-200. The outputs will just barely
fit physically. The drivers will also barely fit. You might have to drill the Q13/14
holes out to mount the drivers closer to the PCB.
That the physical half of this. Electrically - compare the "typical" current gain
of a 2sc2922 to a njw0281 (below). The drivers will see a higher load <8R , especially
at 4R. In fact , you will never reach the 3 pair 2SC2922/2SA1216 maximum
SOA before driver failure.
In short , the badger is an EF2 designed for high beta outputs.
You might get away with 2 pair in the badger , here you could just run the VAS at
10ma Ic.
The multi pair 2SC2922/2SA1216 amps I've seen were all EF3 with huge mt-100
drivers.
(below 1 and 2 - 2922 and 0281 - middle plots)
OS
