Portable Bluetooth Boombox Amplifier
I am trying to make a portable Bluetooth boombox but can't find an amplifier that will work. I have four 8 ohm 20W speakers and one 4 ohm 30W sub. I want to power the amplifier using a 12V battery. I want to use a 2.1 stereo amplifier but I can't find one that will meet these specs. I want to stay as cheap as possible. I am new to audio electronics and could use some help. Anyone have a good idea for an amplifier I could use? Thanks.
you could run 2 of your 8 ohm drivers per channel and run them in parallel to achieve 4 ohms per channel. parts express sells a few 2.1 amplifier boards as well as a few different types of bluetooth adapters. im in the hunt for something similar and havent found much for options. hopefully someone else can chime in with some ideas.
I usually use given-for-free car head-units, some incorporating a tape player or a cd. SMPS power supply works for me...at home 🙄
But you need to fiddle inside to change something, sometimes...
I also play with the VLP ( very low power ) old little 2.1 systems that have the tiny 16 DIP amplifiers...1 W per channel, 3 W in BTL configuration.
Not the Logitech monsters that have HUGE power available on board !
Those systems I described use old linear amplification, though it's rather inefficient compared to the digital class D, as most power goes into heat.
Now we talk about speakers: those make the sound we hear, so the game
is there. The question when making a portable battery powered system is:
what is the desired headroom ( deciBel, SPL, crest factor and many more if you concern the sound ) and for how long ? 🙄😕
This is what I planned on doing. I have everything I need for the project except the amplifier
tpa3116 is a nice amp.
idk if you will be happy with the crossover on the suggested module.
for a first attempt you should try a fullrange speaker imo.
Visaton BG20 is really nice driver for 25€: high spl, nice bass.
i added a piezo tweeter (monacor 5€ piezos are most similar to the original motorolas) parallel to the woofer, with a simple 1uF cap in series with the tweeter.
best improvement for the bg20.
but you won't need that from the beginning.
a real multiway system needs a bit more knowledge imo.
i had only one bg20 in a described cabinet with me a few weeks ago in the park (it was with a tpa3316 board i modded to mono).
a guy stopped and asked where the music is coming from.
he couldn't believe that that simple box was everything.
he told me he had built several mobile boomboxes with car audio stuff before, but never got a result like this.....he should have heard my big outdoor party machinery!!!
I did some search on a similar project that Im doing right now
Box BT Sub and Jack
Brand ventor link
TDA3116 YJHIFI elec_mail2012 YJ HiFi TPA3116 2.1 + CSR4.0 Bluetooth 4.0 Digital Amplifier Class D 100W+2*50W | eBay
TDA3116 YJHIFI sep_store Finished TPA3116 2.1 digital power amplifier Bluetooth 4.0 digital amplifier-sn | eBay
TDA3116 Sure Sure-hifi
2 X 100W Class D Audio Amplifier Explorer & Adapter & Bluetooth, Remote Control | eBay
YJHIFI T-mail2013
New TPA3116 2.1 Bluetooth Amplifier Board CSR4.0 Class D 100W+50W*2 AMP Board | eBay
Box BT and Jack
YJHIFI sep_store
Finished TDA7498 Class D power amplifier Support bluetooth (include Power supply | eBay
TDA7498 FX1602s Quality-gadgets HiFi Digital TDA7498E Class D-Amp Stereo Bluetooth Amplifier + 32V 5A Power | eBay
TDA7498E med alt FX1602s savebase HiFi Digital TDA7498E Class D-Amp Stereo Bluetooth Amplifier + 32V 5A Power | eBay
TDA7498E YJHiFi along1986090 Finished TPA3116 digital amplifier Bluetooth 4.0 50W+50W (Standard version)-sn | eBay
TDA3116
Box Sub and Jack
YJHIFI CAIZHIXING
Free Shipping TPA3116 2.1 Completed 50W+50W + 100W Class D Amplifier Board with Case Power amplifier We are manufacturer-in Amplifier from Consumer Electronics on Aliexpress.com | Alibaba Group
Box BT and Sub
YJHIFI sep_store
YJHIFI saymlove
YJ HiFi TPA3116 2 1 CSR4 0 Bluetooth 4 0 Digital Amplifier Class D 100W 2 50W | eBay
BT sub and Jack
NN sep_store
Assembled TPA3116 2.1 Bluetooth amplifier board (100W +50 * 2)-sn | eBay
NN happyshop1982
TPA3116 2.1 Bluetooth Input + analog input amplifier board 100W +50WX2 YJ | eBay
Sub and Jack
YJ happyshop1982
YJ TPA3116 2.1 2*50W+100W Class D amplifier completed board | eBay
NN Besram-tech
TPA3116 2 1 Bluetooth Analog Input Amplifier Board Class D 100W 50 2 Amp | eBay
BT and jack
NN T-mail2013
New TPA3116 + LM1036 + CSR8630 4.0 HIFI Bluetooth Amplifier Board Class D 50W*2 | eBay
TDA3116
BT
NN T-mail2013
New TPA3116 Bluetooth Amplifier Board Class D 50W*2 Amp Board CSR4.0 | eBay
NN diytalent86
Assembled TPA3116 CSR 4.0 Bluetooth Class D amplifier board 50W+50W | eBay
I picked up a welling centre speaker for $15, added a ta2024 amp, 12 18650 cells in 3 parallel x 4. I added a 2.4gig (non Bluetooth) RX.
I put the 2.4 TX in a small enclosure which has 6 18650s (2 parallel =, string of 3) added a 5v dc-dc, a small mp3/sd/radio combo, 2 Bluetooth RX and 2 line inputs and designed a 5 channel mixer with an extra 5 momentary push buttons which monitor each input to a headphone amp.
Beach party mixups will be on soon. 2 ppl connect phones with BT, 2 with line and someone can mix it up. Cost less than $100
