Class-AB meets Class-D: Yamaha's EEEngine Topology - where are this Diy Projects?
:redhot: hi andrew that is supercool with the right power supply current (which is obviously igbt smps ) it will produce around 14,000watts rms at 2ohms :spin::redhot: P=V2 / R power=voltage squared / resistance"impedance"
very great andrew congratulations again. :up:
hi there ,,,
i know i'm late about this project .....
@andrewlebon ....would you care sharing the details of those coils and toriods on the class d side of the project? I was researching on the net about those coils and toroids but haven't have any luck.......
namaste..
macweb
hi all
i wonder between class d, ab , h ,hd or td what are advantages and which one is clearer and cost effective than the rest .
if the amp is used for pa
below images class td lab gruppen in fp 10,000 uses 12outputs per channel and is very stable at 2ohms wattage at 2 ohms is 2500watts
diysmps
  • FPplus_Series_AE_Specifications_AES-FP10000Q_V3.pdf
  • FPplus-Series_Technical_Data_Sheet_TDS-FP10000Q_V9.pdf
