Seriously Unlikely .. as it's a cheap clone...
If that's right then no amp in the this thread is actually using a Tripath chip? When did the NOS stuff run out along the way? Are none of them genuine? How about the speculation that the same factory just kept making chips even after Tripath themselves filed for bankruptcy?
From what I heard, Cirrus Logic acquired the Tripath patents some time back in 2008-2009. There is a possibility that Tripath chips may emerge again.
By the way, the latest version of Lepai LP-2020A doesn't use Tripath chipset anymore.
Well, thank you for the info, but that doesn't answer any of the questions... Save that you think no one is making Tripath 2020 chips now, is that right?
I don't think so... The remainders are surpluses bought by Chinese companies.
Do you know if those surplus remainders likely to be "real" tripath TA2020's, or was someone knocking off imitations for years (not made the same as the originals or even on the same production lines?)
I have the Lepy like the one in dgirdler's and Jake's posts, with the larger chip. It's labelled as a TA2020, obviously.
I'm just curious, and also I have a friend who's an audiophile and was considering one of these as a birthday present - once i've swapped out parts
Sorry, I am not sure so can't answer your question.
By the way, the retail price of a genuine Tripath TA2020 chipset is around US$3. If I were to make fake amplifier chips, I won't choose such an inexpensive model. My production cost is about the same whether it is a TA2020, TA2050 or TA3020. Furthermore, knowing my clients (manufacturers) will slash the prices by 30-40%, it just doesn't worth my effort to fake such a low-cost chip.
Bottomline is the Lepai LP-2020A+ amp costs us very little money. Just be happy with its value, enjoy the music it produces and stop doubting the authenticity of its chipset.
I have my Lepai amp since 2011. It has been in service for almost 4 years and it still works like a charm. I paid about US$18, with shipping, for mine back then. I never doubt the authenticity of its components... Why? Because I couldn't find a better sounding amp for the price I paid.
...couldn't find a better sounding amp for the price I paid.
I never implied you could. I'm merely curious about the components inside. I like knowing as much as i can about something before i take it apart.
Understood. I would do too, but not to doubt anything. Just enjoy the music it gives.
Trying again...
Anyone....
Anyone....
Hi all. been reading...a lot...not sure if I missed my answers above.
1) I opened up my 202A+. Just above where C20 and C21 would go appear to be two surface mount caps. Nothing in the holes for C20/21. (See pic). The amp worked before I dug into it (ruined the opamp pads, will start a new project now that I've practiced on some refuse boards).
Any one else see this? They measure approx. 3uF in the board.
I assume I can remove these and put in replacement caps in the holes. Some one stop me if I'm wrong.
2) My board came with two 470uf caps and one 220uf cap. The parts lists I've seen call for two 220's and one 470. Did Lepai change their configuration, or put the wrong cap in?
3) What's the most popular replacement opamps these days? I know that's a huge debate and I'll read more above.
Thanks in advance.
Dave
Been away for awhile , I notice now Lepy have TA2024 ??
Aliexpress.com : Buy 48pcs/lot with 12V5A power supply 2015 NEW (original lepai) Lepy LP 2024A+ HiFi Stereo Power Amplifier Output 20WX2 IC TA2024 from Reliable lot lingerie suppliers on Kingbirds Electronic Co.,Ltd | Alibaba Group
Both TA-2024 and TA2020 have different sound characteristics. Personally, I still prefer the latter.
Wow,
Opamps are in sockets and no heatsink on the 2024 chip. Very interesting.
I think they omit the heat sink to cut cost.
Isn't it Lepai, not Lepy?
Both Lepai and Lepy refer to the same products. The name "Lepy" is a registered trade name in North America, whereas "Lepai" is used in the rest of the world.
For Canada, the new packaging should state "Lepy" on it.
The Lepy LP2020-A chip looks like a "slug-down" version of TA2021B (supposedly same die as TA2020 but smd package). Is there a official datasheet and a source to buy these chips?
Both Sony (Part # 875963811) and Hitachi (Part # CP07681U) did license the TA2020-020 doubt they are in production.
Profusion claims to have bought tripaths own remaining stock when they went bankrupt (probably largest part where stored at 3rd party sources around the world at the time):
TRIPATH
TA2021B
TRIPATH
TA2021B
I'd like to increase the maximum volume of my Lepai LP-2020A.
Basically I am satisfied with the output that it can produce, but some songs on my MP3 player are very silent. Or if I attach my phone to the amp, the maximum volume is limited as well.
Can I use some kind of preamp or modify the volume pot somehow?
I tried normalizing my MP3's and increased their gain, but the player tends to clip then.
Try using a pair of speakers with higher sensitivity. Preferably more than 90dB/m/W.
That sounds like a workaround, but wasn't exactly the solution I had in mindTry using a pair of speakers with higher sensitivity. Preferably more than 90dB/m/W.
I'd like to keep the speakers I already have.
- Class D
- Lepai T-Amp with TA2020
