Hi !
reading around i found this intriguing comment about using high value of uF very close to op-amps.
Ok .. maybe 6800 uF is a little on the high side.
But i see very few uF used normally. I have listen to a preamp based completely on opa604 with 2x1000 uF close to the opa.
It sounded both clean and not particularly solid-statish ... i would say very good indeed. Clean as solid state can be but also not hard or harsh.
What do you use normally ?
Thanks a lot, gino
... Here's some of what have learned about op-amps.... Put 6800uF at every power pin of the op-amps, all the op-amps. This will make your op-amps disappear, no more noise, no more distortion! Bass, as good as the circuit can deliver...
Thanks a lot, gino
