Have you discovered a digital source, that satisfies you, as much as your Turntable?
For me the HAP-Z1ES I mentioned gets about as close as I have heard, but I still find in most instances the TD124/II with SPU A95 and Schick arm just does some things better.
The HAP does seem to outperform my lesser table and pre-amp combo by a small margin, and seems more analog like than my modified SCD-777 sacd player.
The convenience of digital is hard to beat, and there are some recordings that are pretty convincing, and unfortunately many more that are not.
The question is primarily for the Guys and girls, who have a quality LP setup(for proper comparison), that have been trying to find a digital source, to compete with the excellent sound of LP's.. By competing, I mean , when you play a digital source, you say, wow, now I can hear the same detail and resolution, recorded spaciousness, naturalness and liquidity, as LP's..
Any dedicated LP lovers, who have reached digital heaven?
what digital components are you using?
All my old music is on LP, so it would be like cutting my arm off to throw them out. But soundwise, digital wins hand down. If it doesn't, something is wrong with your setup.
And I also wanted to add that we should not use coaxial cable to the SPDIF connection (if < or = 1 meter) . I advise braided ptfe wire cable (russian mgtf is very good for this purpose and braided wire beat some xxxx $ spdif cables !) .
Braided cable, I would at least hope you mean twisted pair!!!
Using 75ohm BNC and 75ohm co-ax would be the best bet signal integrity wise..... and that's what you are after.
No, I want to talk about braided cable, not twisted ! I know what I do.
For this I take 3 ptfe insulated wire of 0.12 mm2 (russian mgtf) . I put two wire to the ground and the other on the signal. On the third of the length (side dac) I put a suppression ferrite. This cable has far exceeded quality cables such as Wireworld starlight for a few $. This cable works well provided it is quite short (<1 m). Capacity about 45 pf only.
Not the best solution for transmitting the digital signal. or for minimum jitter as that seems to be the new bogyman in digital audio... digital is very robust though as designs with no ground plane for return currents show as they work, but for ultimate signal integrity (which is the major concern) then goo engineering practices have to be followed...
For SPDIF co-ax at 75ohms would be the BEST solution, followed by twisted pair (not really the best) anything else is a compromise, but will work to an extent ( below 1m in this case showing that signal integrity issues are being added by a far from optimum cable).
Have you ever tried this type of cable before saying a coaxial BNC is the better ?? (remember < 1m)
For those who have the courage to read this article:
kusunoki
The difference between the non-oversampling DAC and the conventional DAC with the digital filter lies whether you attach importance on the accuracy in the time domain or in the frequency domain. In other words, whether you choose the musical performance or the quality of a sound. This trade-off line defines the boundary of the current digital audio format .
A natural, stress-free sound that communicates the musicians' intention directly to you. That is the sound of non-oversampling DAC. The feel of this sound is closer to that of analog reproduction.
Thanks killmister.
Your work is well organized..
I'm going to make the TNT.
I'll order the parts and put the project in the projects lineup..
I likely have some questions later..
Thank you.
also forgot to say that it is better to put a lm317 instead of irf830 . In the original design , there are oscillation problems.
I built this dac there almost 15 years and I do not get enough . Some audiophile friends were amazed by this dac against their high-end hardware .
