A14 ,do you mean AX-14?
A14 CFA amplifier with diamond OS.
Where are pcb jpeg or pdf ?A14 CFA amplifier with diamond OS.
posts #3990, #3991 and #3999
Use BC546, Rb 10k and Rc 1k.
Thank you..
I noticed this LED circuit from 555 protect? will try to add this also .
Hi thimios, if you can wait a few days ...
There is an improved layout for the A14, but it is not yet tested. However, I will do that in the next few days.
The changes are:
- Separation from SGND and PGND
- TL071 instead TL072
- some changes in the routing
- Capacitors in the power supply voltage
- Space for small heatsinks for drivers
regards
Olaf
olafk
Very nice board, I am not sure if it is good idea to run the high current output track just next to the input node (op-amp).
Nice and compact.
Nice and compact.
Hi, yes, that could be a problem. In the first layout, I have found nothing. But I'll see it 🙂.olafk
Nice and compact.
Maybe someone else has built the A14 and can report ?
regards
Olaf
Yes i will wait for a better pcb.I agree that strong signals must be away from small signals in pcb .Hi thimios, if you can wait a few days ...
The changes are:
regards
Olaf
Take your time.
regards
Olaf
You can use wire jumper instead track like in B500...
APEX OP LINE PREAMP.
Sir Apex pls. check if this is right Sir ? and can i use this in AX14 amp. sir
It is ok,
Mr Mile
Just for fun I have soldered 22pF caps in A9 IPS, look what have You done 😀
Scale is 500ns (OPA2134 in it). It is really fast (i did not removed input filter for the measurement). Sounds fantastic.
You can also use less than 2k2 series resistor at the input, or try some other combination like 100R and original 330pF, etc
One channel on balance pot must have reverted pins (input and gnd)
thank you so much sir Apex for your reply...god bless Sir
something like this...
Sir, Apex pls. help me to identify which pot. pins is mistake thank you Sir.
Thanks Sir i understand which is mistake thanks so much sir Apex sir.
Sir Apex like this Sir?
A9 is the king!
I am not sure where to post it but I will take a chance and post the resaults here.
I have spend plenty of time with A9 based amp, lot of listening tests, measurements, swapping the resistors over and over (I only have to match VAS load resistors - I do not know exacly how to calculate them). The key was to find proper ratio (gain) in fallowing stages. I was recalculating bias in all stages with differed ratios + splitted NFB values and the bellow setup gave me the best resaults - H2 is dominating all the way threw audio band and the harmonics spectrum is very flat, amp sound superb.
Simple suff can sound and perform very well. Bellow prototype board and schematic.
Highly recommended!
Thanks Mile.
Highly recommended!
Thanks Mile.
- 100W Ultimate Fidelity Amplifier
