100W Ultimate Fidelity Amplifier
almost ready to rock... I have no so much time due Ice Hockey World Championship 😀😀😀
Mr. Mile,
During some test I've done on this protect, when applied +/-DC on input.
The LED lit on but relay did not deactivate, (referring to the attached drawing) below are the parts used, the rest remain unchanged.
20R/5W
ZD 6V2/1W
2K2 - resistor used in series with LED to increase brightness.
Question: What's the changes needed to deactivate the relay when the LED lit on?
  • 478687d1429631731-100w-ultimate-fidelity-amplifier-apex-simple-protect-ver_2_0-gray.jpg
Mr. Mile,
20R/5W
ZD 6V2/1W
Can you measure voltages on TIP121...
Increasing 2k2 will slightly release the relay but its loosing the brighness of LED( too dimmed if i used the original value 15K).
Today i tried to install 1K5/1W resistor in parallel of relay coil, works perfect without loosing the LED brightness.
Thanks for the advise Mr. Mile.
Mr Mile
Just for fun I have soldered 22pF caps in A9 IPS, look what have You done 😀
Scale is 500ns (OPA2134 in it). It is really fast (i did not removed input filter for the measurement). Sounds fantastic.
This is really confusing ! 😕
So many pages and I suddenly see A9 mentioned. What is it ? Power amp, Pre amp ? OPA2134 ....where ? Maybe the post number can be mentioned ? Cap, where, and how does it speed up things making something fantastic ? :bawling:
Of course you can see that I am not reading this thread every day, post by post , hence the confusion ! 😉
Reference to some post where there is a circuit diagram ( of A9 ) would have been helpful !
Cheers.
Cheers.
A9
You can use this circuit for protect and ready leds.
Still AX20 😀
still AX20 progress 😀 and only one channel 😱
with upgrade SMPS up to 350watt
i try to set 20mV on R emitor (i'm used 0.33R), why final transistors so hot,
now only run at 10-15mV it's enough but still not satisfied 😀
20mV of Vre biasing gives 60mA of bias current through each output pair.
It looks like you have a 6pr output stage plus a pair of drivers.
If your supply voltage is +-10Vdc then your output stage has to dissipate ~8.5W per 10Vsupply
a +-50Vdc supply will result in >42W of heat in your output stage. That will be HOT, before you start playing any music.
Thanks Mr Andrew to explain it,
that means total rms out of power will loss due to dissipate ~8.5W per 10V supply, is'n it?
i'm used 80Vdc (+-40Vdc) of supply and load will use max 4 ohm,
how many watt will produce this Ax?
