Dear Andrew,
I don't want to have an argument with you since you help a lot of people here, myself included, and I'm very thankful for that.
Nevertheless, I actually carefully read the F5 manual as well as a lot of posts in this forum before I started the build 4 years ago, but in spite of that, I missed the low Idss symptoms comments. But if you read my post #14795 you'll see that I found the answer myself, on a post about that problem.
So, again, thank you for the help, and I'm sorry if I made you lose some time by my fault.
Matched K170/J74 will be available in the store soon
Diyer dream become reality
DiyAudio store future bestseller
So there isn't anything else I can buy to replace the JFETs?
It's almost comical to realize that many vacuum tube types have superior availability to these JFETs. Ditto for some medium power lateral MOSFETs - Renesas discontinued the 2SJ76/2SK213 types years ago, and there is no really decent substitute for them.
If only they manufactured P-channel valves.
Unfortunately, all positron-emitting cathodes were used up to build the Death Star and Imperial tube company went bankrupt after that...If only they manufactured P-channel valves.
Sure there is - few cheap BJTs will do the job and won't sound worse than JFETs.So there isn't anything else I can buy to replace the JFETs?
Actually, JFETs are replaced by Q3,Q4 (running at 4.5mA). Q1,Q2 make strictly neutral buffer that polarizes Q3,Q4.
Q5-8 make constant current sources for the input stage.
No need to deprive yourself of a good amp for such a trivial reason - lack of JFETs...
- F5 power amplifier
