The Boominator - another stab at the ultimate party machine
When I get a chance to retry will I be able to just glue again or will I need to sand back to wood to clear the old glue off?
I did some testing of Gorilla glue on film coated ply today and a T joint was surprisingly strong. All I did for prep was wet the exposed wood with water, scuff the film and wipe it down with IPA. I am very confident that it will be fine for the dado joints in my build.
Did you resolve the cause of the 10mm gap?
Yes, after chipping all the chemical metal off and sanding back the epoxy there was a 3mm gap when dry fit. I think I used way to much chemical metal which set before I clamped it and I also think the rubber baffle on the driver didn't compress as much as I thought it might.
I've routed out behind the magnets and glued with pl premium. I'm away until Wednesday so hopefully I'll come back to a good bond.
@Duffy. Just that it looks more professional and is easier to use. Performance wise it won't matter much indeed.
@Steve. That's with the piezo tweeters. Wirewound resistors have quite a bit of parasitic inductance, which acts as a lowpass filter. Not something you want when you use it as a highpass filter on your piezos. For this application it's fine.
I thought we weren't supposed to use wire wound resistors for the x-overs?
Carbon film was preferred?
Saturnus specified Carbon film for piezo tweeters. In this application (PHT-407 tweeters) I don't thin a few uH will matter but let's do the math. 🙂
The inductance is between 10 and 20uH (I could not measure directly so I could be off a bit). If we assume I am off by a factor of 2 (40uH) the -3dB point is in the 80kHz region. I don't think that is meaningful in the scheme of things.
Actually. It's carbon composition or metal film but not carbon film or wire wound with piezos.
Anyway, I normally recommend metal film with the PHT407Ns there's really not going to be much difference if it's wire wound, carbon film or metal film with the PHT407Ns. I wouldn't recommend carbon composition with those though.
but digikey has 2 ohm in 3W. So, I figured I would just put two of them in series and get 4ohm with the required power handling.
Actually, I bought several different values (2ohm,4.3 ohm, 6.2 ohm, 8.2 ohm) and was going to hook them up with a dip switch so I could dial in the attenuation--Saturnus had mentioned that some experimentation here would dial in the tweeter in for the type of music you liked.
They were $0.61/each at digikey.
Or buy a bunch of 2 ohm resistors and use series/parallel connections to test.
Yeah, then I'd want a PCB to make the soldering easier. 🙂
In all seriousness, in this application the Dayton Audio resistors will be just fine.
I did some measurements and these resistors are 0.003 to 0.004 mH. That is a factor of 10 smaller than I used in my calculations below. Fc moves to 1 MHz
