Philco K1629 Upgrade Options
I have a Philco integrated amp that I've been using to teach myself how to work on. It is a simple single 12ax7 driving tone, volume and balance pots through two 6bq5s. I've recapped, rewired and reresistored it. I recapped it exclusively with orange drops, other than the electrolytics. It sounds alright and much better than pre-recap, but I'd like to see if I can make it sound better.
I'm looking for any suggestions/ideas for improving the circuit and improving the overall performance of the amp, and looking to learn more about how these amps work while implementing your ideas.
My ideas thus far:
1). What would adding a negative feedback loop do to the performance?
2). What would adding another preamp layer do? I have a good spare 6eu7 from another stereo.
3). What would replacing the three small output transformers with one or two beefier units yield?
4). What would putting in a bigger transformer pushing more volts do?
Any ideas/suggestions would be appreciated. I'm looking to get the most out of the circuit and learn more about how it works in the process.
I've attached two copies of the schematic.
Thanks,
It looks like you have a pretty decent power trafo. IMO, that's worth saving, but much of the rest is, unfortunately, guano. The cheapskates have mono bass PP. YUCK! I've seen that kind of trashy circuitry before and remain singularly unimpressed.
Better sound, you said.
Buy proper SE O/P "iron", with both adequate power handling and bandwidth. Edcor's GXSE15-6-5K will work with both 8 and 4 Ω speakers and the price is quite reasonable. The power handling capability in excess of the 6BQ5's capability means the "iron" will reach deeper into the bass region than the spec. sheet suggests.
Simplify the signal path. Get rid of shaping circuitry and retain only listening level control. Your, thinking about a GNFB loop is spot on. Both linearity and damping factor are positively impacted. A 12AX7 section voltage amplifier should prove adequate.
The Edcor O/P trafo linked above offers you a choice between UL and full pentode mode O/P. If you go full pentode mode, regulate 6BQ5 g2 B+ at about 250 V.
Another improvement you can consider is CLC filtering the B+. The 6CA4 rectifier is quite competent. Take advantage of its capabilities and use a 47 μF. 1st filter capacitor.
I should add that I'm listening to the amp through a set of speakers and crossover from a 63 Magnavox tube console. 12 inch woofers and horn tweeters.
Don't know the efficiency db rating on these but I can only assume that using a crossover they aren't up to the needs of a SE amp. With that said to keep stereo capability would I have to use at least two opts to replace the three existing? Would a pair of the GXPP15-6-5s fill the need here?
By CLC, are you recommending incorporating a filter choke after the first filter capacitor, replacing the 1K 5W resistor. I'm on board, but not sure how to calculate the ohm value for the choke. My other amp uses a 55ohm choke to yield a 5V drop from 330V to 325V. Here I need to drop 45V from 220V to 175V. Doing the math would I need a roughly 500ohm choke?
You could probably lose the tone controls. Get better OPTs (EDCOR are good), use LM317 current sources to bias the cathodes use a CLC filter in the power supply to reduce hum.
The first thing I would do would be to give each 6BQ5 it's own cathode load (a 317 CCS bypassed with a 1000uF capacitor is ideal).
I would use this choke if I were you https://edcorusa.com/cxc100-5h-200ma. Connect it with a 47uF capacitor in front of it just upstream of your 220V rail.
Breaking it down, starting with the power supply and filtering section
Thanks for the input.
I need to break this down a little bit, starting at the power supply.
At the PT I have probably 120 coming in at the wall being boosted by secondary to ~190. This runs to the 6ca4 and gets boosted again to ~220. These are given. With the suggested mods I'm not impacting any of these figures. Also, I can assume my modern line voltage pushes all these numbers up around 5 volts.
I believe the suggestion is to run this 220-225 volts first through a 47mf electrolytic into a 5h 200mA choke. At 200 mA and 58ohms this will drop my voltage ~11.5 volts. This is going to drop my b+ somewhere in the 210-215 volt range.
Couple questions at this point.
1). If I run 2 Edcor GXPP15 4-5k Output Trans, will that 210-215 on each center tap be enough to get full operation from the transformers and 6bq5s?
2). If I want to stay true to the old school technology in the rest of the power supply(translation: run from more modern technology I don't understand) would I pick up the rest of the rcrc from the existing system? Right now after the 220 line out it runs 1000ohm/5w resistor to 30mf electrolytic to 1800ohm/5w resistor to 10mf electrolytic. This yields resistor voltage drops of 45 and 50 volts respectively.
Thanks for the help.
Yes, you do need a pair of O/P trafos (1/channel).
You should get about 250 V. of B+ out of the 6CA4/EZ81. Perhaps a tad low, but nothing terrible. To squeeze a few volts more out of the PSU, switch to SS B+ rectification using 2X Cree C3D02060F high PIV Schottky diodes.
CLC filtration is quite sufficient for O/P tube B+. All that's additionally needed is RC section decoupling, to feed the small signal circuitry.
The screen grid in a 6BQ5/EL84 is plenty tough. So, UL mode "finals" make considerable sense, given the "short" B+ rail. Unfortunately, the 12AX7 triode is a wimp, which may not be up to driving a UL mode O/P tube. That issue can be dealt with by "borrowing" the ZVN0545A buffer from the phono preamp schematic I've uploaded. If you FET buffer the 'X7 voltage amplifier, employing "fixed" bias O/P tubes is definitely feasible. Yes, you have to build a low voltage negative rail to use "fixed" bias, but you gain the opportunity to squeeze 5 honest W. out of each O/P tube.
I have on hand a 12at7. Could I use the existing 12ax7 as a gain stage and then utilize the 12at7 as a driver/phase splitter to feed the output tubes?
If at all possible I'd like to maintain the "integrated" original nature of the amp. I want to improve it and beef it up, but I'd like to keep it free of newer bits and pieces of tech. Also, if at all possible I want to maintain the preamp tone and volume aspects.
It may be silly, but I'm aiming for an integrated that can still drive it's turntable and an iPad and I can tweak treble or bass to suit the music I'm listening to at the time.
Those cheapy consoles used piezoelectric cartridges, along with low grade record changers. Can you say record eaters? :bawling: :mad: An old Technics, Pioneer, BIC, etc. TT off EBone or CL, a modest MM cartridge, and a phono preamp are what you need to enjoy LPs, without filing for bankruptcy. While opamp based, Jim Hagerman's Bugle2 is certainly sufficient for a "budget" system. Please observe that the Bugle2 employs passive RIAA EQ, just like the tweaked RCA setup I previously uploaded. :)
You certainly can retain an "integrated" amp. Adhere to the KISS principle. Use a pair (1/channel) of Mouser stock # 31VJ501-F3 pots. to control listening level and channel to channel balance. Except (possibly) for source selection switching, use no other controls.
Lads, you need to remember passive eq is only a good idea when you have obscene amounts of headroom, such as you have with valve preamps. Not so good for op-amps when you only have +-12 or so output voltage.
I agree with Eli, those autochangers you find in most older valve equipment are complete drek. With 78s I still shouldn't want to use them :D ! They track at about disgusting levels (7+ grams) and are about as compliant as a brick :p .
There is something you will notice about these amps and that is
They are biamped with an extra transformer that feeds the bass from both channels into one trafo.This is why it is best to put two new opt trafos on like what was suggested. Depending on how far you want to go and being you are using this amp as an educational tool,you can utilize the bass trafo if you want to get clever just for experimenting and playing with crossover points.
If you don't mind please elaborate. Outside of upgrading using more modern circuitry components, I'm up for anything, but not sure what you mean when you say playing with crossover points.
Thanks again.
One more shot at adding a layer: Mullard 5-10
I haven't gotten much play on this idea thus far, but I'm going to take one more shot at it with this thread.
Right now I have a two channel 4 tube push pull amp. 6ca4, 12ax7, 6bq5 6bq5. I have seen a few schematics on line that utilize the front of this amp tied to another preamp tube such as EC86( I think) used to drive a pair of larger output tubes. I also found at least one reference to using a 12ax7 for a gain stage feeding a 12at7 for a driver/splitter stage then to output on larger tubes again.
It may be a fools errand, but would it be feasible to use a similar scheme as the Mullard 5-10 but going 6ca4, 12ax7, 12at7, driving my 2 6bq5s? I haven't been able to find a schematic yet with this configuration.
Any help would be appreciated.
The 5-10 is a mono setup. The power trafo/rectifier combo in your possession will not support a quartet of 6BQ5s plus small signal circuitry.
VERY few recordings benefit from tone controls. Really good tone controls are somewhat complicated and can't be put together from a single triode/channel. There is no need for additional voltage gain, when tone controls, with their losses, are absent.
Adhere to the KISS principle! Forget about the 12AT7, for now. It will be used in some future project. ;) Better O/P "iron" and straight forward signal topology are your path to decent sound.
5 or so WPC are enough, IF you use the right speakers. Be frugal, not cheap. You can't get a "Caddy" for a "Chevy" price. If you're careless, you can pay for a "Caddy" and get a "Chevy", or worse a "Yugo". :(
Okay, thanks for putting this in terms I could better wrap my head around. Would it be fair to say that this amp is a mono unit that the designers are cheating stereo out of by splitting the output between the three O/P trafos?
On the front end the amp is going to be stuffed back into the console it was born in. It came to me with two functional speakers. A 4 inch original unit and a 6 inch RadioShack. The plan is to retrofit the console with the speakers and crossover from a late 60's Motorola I also have. Not perfect by any means, but it sort of fits the theme of this rebuild.
I will be taking your advice about the TT though. That will mean adding a phono preamp. Maybe the 12at7 will find a home in the end.
Technicalish Question: O/P Trafo Wattage and Output Ohms
Regarding the Edcor OPTrs that have been discussed as replacement units on this project.
Options:
1). GXPP or CXPP, seems the CX series is total overkill for this project so definitely going with the GX series. Yes?
2). 10 or 15 Watt? Not sure exactly how this works, but I think this indicates how much power the unit can handle before failure. In this application is 15 watt overkill? Or would you say, for $10 more each I have better trafos on hand that can handle more for future upgrades to is amp or other projects?
3). Output ohms? The ohm ratings on the various speakers I have available for this project are all over the map from 4-6 up to 14-16. With that said should I go with the lower 4 ohm output so I'm safer not to blow anything downstream?
The transformer wattage doesn't have much to do with preamature failure. The higher the wattage, the more magnetic headroom you will have so your bass response will be better.
I would recommend the 15W ones as they will give you a better frequency response and also lower distortion, but they are more expensive. 8 Ohm would be best. Just pick a pair of efficient speakers that you like and then order a transformer that matches their impedance.
The primary impedance of the transformer should be about 5K. The GXPP would be your best bet.
The amp design is stereo but I have no idea what T3 is for.
Monty,
The Philco is very much a "bottom feeding" setup. T3 is a mono push/pull bass only trafo. Notice that the otherwise identical T2 and T4 are phased 180o apart. T2 and T4 are small, which makes them incapable of handling bass. The setup is a grossly inferior, dirt cheap, implementation of the satellite/subwoofer concept. :mad: The thing rates lower than whale guano and that's on the bottom of the ocean.
The original console was at the very bottom of the product line. Of the OEM magnetics, only the power transformer is worth keeping. The 6CA4/EZ81 rectifier, with its 150 mA. capability, is decent too. The cheap consoles frequently used the power amp's PSU to power a tuner. That's why you find relatively robust power trafos and rectifiers in what otherwise would be utter garbage.
Top of the line console amps were not "horror shows". For instance, 1 "MaggotBox" amp uses a hefty power trafo, a 5U4GB (250 mA.) rectifier, a CLC PSU filter, and PP 6BQ5/EL84 "finals". The O/P trafos are mediocre, but not trash.
