35" Ribbon build
Hi Guys, I thought I would share some images of a build im doing for a client in South Africa. The ribbon is a 5 segment it measures 6 ohms resistance and is 18mm wide and 35" long. The client wanted a narrow baffle similar to the B & G Radia 520i. The baffle is 1.1m x 220mm wide. Iv used nylon bracing bars to try and keep the flux centred between the ribbon. My magnets are N37 3/4" x 2" x 1/4". My pole pieces are 3/4" x 3/4" solid bar (No idea how this measures on Femm) IMG-20150501-WA0014.jpg
Vary nice..........is the foil on bouth sides?...look to be free hanging?.......one thing I never got to hear was the two sided Apogee Stage 26" ribbon.......
I gess it would have gave more image hight....but was on mylar not capton so it could get hot an fail...but not minny did.... so I have read...........but who knows
thanks for the pic
thanks for the pic
Hi Tyu, Thanks.
The ribbon is attached every 180mm to the nylon braces.
For give me..............but I though that had to be glued??
My point is that the apogee 26" has a open spot at the top an bottem of 1 1/2"....an that I could add magnts if I wished... ....
thay did this on later 26"ribbons to get more output?
with the magnets just holding there self.... I could see if I like the sound...if not I could just pull the magnets off......
