2sc2922/2sa1216 help me to find out fake or not
Several Japanese designs used that combination of driver and output in medium power amplifiers. It's been a standard recipe for medium power, high quality audio for around 20 years. It should be fine for 1 or 2 pairs of outputs at +/-50V but if you wan't more power, you need higher rail voltages as well as heavier drivers anyway.
2N5401 or 2N5551 at the input have a few things, like 120V Vce and reasonable gain going for them but you can get better noise figures from KSC1845/A992 without trying too hard. These are about the best available types for the input stage and any medium voltage, low noise, low level audio application. They are replacements for the obsolete 2SC2240/2SA970 that were once very popular. If you are going to use these high quality power transistors, it would seem silly to then use standard grade parts in the input stage. I would try to source the best types you can, in economical quantities.
If you are not following other threads where all these details of suitable transistor types and matches are discussed many time over, at least view the schematics of contributors like Ostripper, Dadod, Vzaichenko and others who regularly design and redesign some exemplary amplifiers with these or similar parts. Look closely at the designs and the types used in them. You'll find similarities with your own, developing ideas.
