Threshold 4000 repair. Need some help.
I am still missing something somewhere. I rechecked everything and found a 300 ohm resister at 1k. Every thing else seems fine. Here are voltage readings at the transistors taken with 10 volts +/- input. Maybe someone will see something and give me a clue.
trans #
400and4000 B
All caps are now film except for 47uf and 220uf at the input. Right now they are polar electrolytic. The picture with the numbers is an old one from when I first started. I needed something to keep the transistors straight.
