PVC pipe speakers
An option is to make a tricolumn Voigt pipe!
Sounds good and are really easy to build.
PVC is not toxic (the polymer) the main problem is all that other stuff added to the formulation, flame retardants dyes, fillers and what have you. These other compunds may or may not be "toxic".
This is my 2" PVC quarter wave TLs project. The sound is amazing and bass is comparable to my Floor-stand speaker! :D
The most tricky point in this project is to determine the driver offset. I tried various offset ratio and found that between 1/5 to 1/3 (may be @ 1/4) are most optimum in sound.
However, until now there are no clear direction on determine the optimum offset ratio and I still need further studies :confused:
