Speaker Cable lifters or stands?
There are exemptions for commercial/long service life equipment including medical products...presumably pacemakers are lead free exempted.
Dan.
Yes. Medical is exempt. Flight hardware, space hardware, undersea cable hardware, weapons hardware, as well as industrial control.
There are/were more exemptions, I've forgotten most.
But as marce pointed out, finding non lead free components is becoming harder. I hate to pre-dip components to remove the lead free coating, it's just another extreme temperature cycle to compromise the part longevity.
jn
There are a few left, Ti is good source for basic logic and some op-amps (not many current footprints or component sizes), I'm not sourcing, its a nucleonics' type job so all components from an approved list with some nice Ladies doing all that... security, guides, restrictions etc. make mil./aerospace seem a breeze... Usually everything goes in a hybrid and you just slap a few of them on a board and join the dots, so much easier.
As I understand it, the ROHS directive was implemented to help keep lead out of underground water due to leaching from buried E waste.
It seems that most E waste these days is reclaimed/recycled, so no such issue really exists.
The cynical might remark that the ROHS directive is another means of guaranteed/planned obsolescence.
Dan.
Nope, lead does not leach out of solder very easily.... It was wider ranging than that, lead just got caught up in the excitement, did many a report with others to try and get lead solder exempt.
Medical devices are not exempt any more, since July 2014....
RoHS July 2014 deadline: medical devices and control instruments - Actio
The arrows are to help ensure that both channels are routed in the same signal direction...ime this is important.
QUOTE]
A.C. signal which way is it flowing?
Been a bit busy so a late reply.
Come on Marce you know better. AC is Alternating Current, it goes with Alternating Voltage. So Power Flow is of course directional. There really are some folks who don't get that.
Now cable assemblies can indeed be directional. Anyone who has an RF network analyzer can test various cables to see differences such as SWR in cable assemblies.
An interesting test for cable is variation of velocity of propagation vs current levels and vs frequency. This may actually show some directional issues.
Now making directional loudspeaker cables is a interesting issue. Having done a bit of measurement and using lots and lots of loudspeaker cable, I will not completely rule it out, but have never seen any evidence of that, it is not on my list of real concerns.
RF cables are not audio cables.... Different kettle of fish... a variation in the cables characteristic impedance will show up for both RF and high speed digital as a slight difference in reflections, nothing new, audio frequencies not really....
How do you vary the velocity of a signal in a particular cable? that's down to the cable construction and dielectric constant of the insulation.....
Bend the living daylights out of it. And as an added extra bonus, is splashes signal out into the environment.
For parallel pairs, run it through a metallic conduit. The permeability can slow it down.
I recall one vendor of speaker cables actually talking about stripline geometry with a varying dielectric thickess.
go figure..
jn
I was referring to some real sensible data from audio cable manufacturers...
HAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHA! Oh wait, you're not joking?
Fred Davis. Dick Greiner. There's really nothing to add to their work. It was a trivial thing then (35 years ago) and even more trivial now. Only gullibility, cupidity, and a total lack of morals has kept the question alive in the tiny niche of fashion audio.
Hello Simon.
Hmmm, power flow/transfer is singular direction, ie source to load, but the conductors required to complete any circuit carry current in alternation direction.
Audio signal peak values are asymmetric, but there is no net DC component in replay/reinforced audio due to HP filtering.
IOW the area under the curves for pos and neg signal polarities are identical, BUT signal pos and neg slew rates and peak values are NOT identical.
This could cause audio equipment differences due to sensitivities to induced noise pickup.
Interesting.
In the Naim cable example photo, I understand that the arrows are to enable easy identification of direction to ensure both speaker cables are routed in the same direction....ever tried to discern cable direction of poorly marked cable in bad lighting ?.
I don't think Naim claims cable directivity per se.
That said, I have encountered image skewing due to opposing speaker cable direction as per my turntable cable experience I detailed.
For this reason as a matter of course I always ensure that stereo cable pairs are routed in one direction.
Dan.
Q is a charged term...
in any event how does charge carrier "velocity" change transmission line equations?
wouldn't seem to have 1st order effect on EM wave prop velocity
small, indirect effects through R loss or maybe internal L?
Actually a bit more, but there is enough noise here.
For fun look up graphene and ballistic transport.
Fun.
That's giving me nightmarish flashbacks of calculating this/single electron transport for single wall nanotubes my first year of grad school. It's just about exactly where I find my ability to do math falls apart. Flipping Euclidean spaces and such and looking at Fourier transformations of 3-D space was just a bridge too far for my brain to construct.
Man has got to know his limitations. 🙂
Easy. They are momentarily stunned by collisions, and take a while to recover.
The term is Collision Recovery And Propagation.
Everybody knows the acronym..😀
jn
