Capacitance doesn't figure - in this model it is shunted by source impedance and load. The TL model works fine, and discrepancy between LCR and TL prediction is negligible anyways. Single cell LCR should be most accurate for audioband risetime, but AFAIK you still use fast step changes, the cause of discrepancy here. If you observe a dependency on C/length in this scenario there is something wrong with your model or you are using fast rise times.Now, most importantly..run a 200 element LCR model using the correct numbers. See how the distributed capacitance works... And, note how absolutely accurate the t-line is when compared with a real model. Don't worry, we've seen that already thanks to Scott.
But assuming spice handles it, I'll waste an hour of my life confirming a large scale discrete LCR mimics a TL, and which in this scenario for audioband risetimes must produce near identical results as TL and single cell LCR.....
Yes, I know. In your model.Capacitance doesn't figure - in this model it is shunted by source impedance and load.
No, the fast step changes do not cause a discrepancy. The tl model is EXACTLY the same as a 201 element LCR model.The TL model works fine, and discrepancy between LCR and TL prediction is negligible anyways. Single cell LCR should be most accurate for audioband risetime, but AFAIK you still use fast step changes, the cause of discrepancy here.
It has nothing to do with fast rise times. TL and 201 element agree absolutely. And, as Davis said, adding the capacitance will speed the system up.If you observe a dependency on C/length in this scenario there is something wrong with your model or you are using fast rise times.
Spice does handle it, I believe that is what Scott used. And he confirmed that a very fast rise time had nothing to do with the accuracy, they superimposed.But assuming spice handles it, I'll waste an hour of my life confirming a large scale discrete LCR mimics a TL, and which in this scenario for audioband risetimes must produce near identical results as TL and single cell LCR.....
Which is what I've been saying all along.
jn
A big discrepancy arises because, with a fast rise time, your choice of where on the resultant waveform to measure 'settle time' affects the outcome. You choose 95% level, which gives a different outcome to say 69%. So, once again, your choice of conditions affects the result. Whereas with audioband risetimes, wave shape is in practice well conserved, and latency effectively uniform throughout the risetime. Only at the 69% mark does fast rise latency match audioband risetime latency.No, the fast step changes do not cause a discrepancy. The tl model is EXACTLY the same as a 201 element LCR model.
And you'd be very worried if a large discrete LCR model did not match TL results. For audioband risetimes all three models should match well in any event. This must include the effect of source/load impedances shunting cable capacitance. BTW, this renders variation of the rf characteristic impedance of the TL irrelevant, as it should be of course.
Anyways, I'll run the large discrete LCR spice model tomo and see.
Scott, I've never experienced this myself, I've never played with it, at all - the cable goes in, as is - my last fancy stuff was 30 years ago.Frank, Dan, please guide me to any documented application outside of audio where wire directionality is a key element. AFAIK no scientific or medical measurement no matter how low level, sensitive, or in any frequency range has a documented benefit. We are not talking about which end to ground BTW.
There may be an effect, depending upon everything, as usual; Dan has come across something, and it's working for him trying the options - so far, I've got what I wanted without worrying about such issues, it hasn't come up on my radar ...
Edit: the directionality thing would be all about the fact that every electrical part is made of up of real materials, which do not have the "perfect" properties so beloved in textbooks. There are always secondary behaviours, which 99.99% of the time contribute sweet FA to the device working correctly or not - audio is one of those funny areas where unfortunately it does appear to have some impact.
For some strange reason I'm led to using the field of winetasting as analogy, 🙂 - which is very simple: you compare competent wines, for various qualities. And what is a competent wine? Well, one without flaws or faults, a very straightforward concept - very easy to look up what this means.Looks like you aren't aware of what bias controlled test is. It's your loss.
What is competent sound? Do you mean high fidelity?
And if you get a incompetent wine, no-one is going to ask the judge to do a double blind test to check whether that is the case or not - he likely spit, wine 😀, in your face ... there are clear "signatures" to the wine not being 'right', part of the learning about wine is to recognise these.
And exactly the same applies to audio ...
Unfortunately some of the world's greatest wines are technically flawed by academic standards.
Right... 🙄
Which still may be acceptable in the bigger scheme of things, because there is a special quality in the wine which is worth the "price" of that flaw. Here a balancing is taking place - technical incompetence offset by the quality of the raw "ingredients" which went into the wine ... there are plenty of audio systems that could be said to fit into this space ...Unfortunately some of the world's greatest wines are technically flawed by academic standards.
My comment about audio needs being "funny" still stands - human ears are incredibly adaptive, they can ferret out an irritating flaw in what they're hearing, instantly judge whether what they're listening to is up to scratch. That's why I talk about having the volume up when listening: most systems fail, and fail badly, on this test - all the little defects are now so obvious, it's impossible to listen to for any extended period; for pleasure, at least. The sign of a system working correctly is that there no obvious audible problems when this is done - there is nothing in the sound that offends or disturbs one, you don't have to "put up with it being loud", it's intense and pleasurable for all the right reasons.
He may be one of the vendors of those money wasting audio tweak products. They hang around on forums and try to diffuse the attention away from damaging evidence to their business.Why are you feeding it?
No, I leave that to folks over on your side of the big water - you lot are masters at that sort of thing ... 😛.
You mean how much you don't need to know and how little you need to understand to make the best best choices in audio cables. The knowledge needed on audio cables to allow the users to make the right choice has been established and published. It's all over the internet. What you've seen last few pages has been nothing more than one poster trying to show that his * is bigger.
* Use your imagination. 😉
I for one would love to see such information on audio cables from a reputable source....
Dan, if people have decided, for whatever reasons, that something can't have an audible impact then it's highly unlikely they will do open minded experiments - I wouldn't get fussed about it, it's their loss ... 😉.
The trap is trying to come up with a reasonable explanation for what's going on - one can end up looking a bit stupid if it dissolves into a heavy duty technical argument, and one's premise is heavily undermined. For me, the point is to achieve competent sound, and really, I couldn't give one tiny snippet of a bugger as to the "why" in the first instance - the aim is to get complete, experimental control over the behaviour, and while on that journey, or later, the "whys" may start to emerge.
you never do come up with anything just more audiophool nonsense, quite often it is the scientific facts that tell you there will be no audible difference, something else you often want to dismiss.... Also don't forget a lot of us work in the world of electronics, in my case over 7 years on Mil communication(especially hearing protection) equipment, so maybe we also actually see experiments, work with acoustic engineers and do experimentation.
Provide some proof, science based.....
Hi Scott.
I don't know of anything documented....I have not attempted to research the subject online, self experience only at this time.
For sure, in most applications wire/cable directionality would not be of concern.
In the turntable example I quoted, the two channels individually sounded same enough, but when listened to in stereo the difference was enough to side shift the stereo image slightly sideways, but not quite the same effect as panning which is of course a channel/channel amplitude alteration.
Flipping acoustic polarity of a system changes perceived distortion, image reality, and also perceived loudness (for sealed box loudspeakers)....as is to be expected.
The flipped one channel cable direction in the TT example caused a similar-ish effect to flipping acoustic polarity....one channel sounded subtlety louder than the other, and thereby skewed the image sideways, but the balance control did not cure the perceived imbalance.
The amp that I ran at the time had Stereo/Reverse/L mono/R mono/L+R mono switching.
I tried every diagnostic that I could think of including shorting the channels at the V15 III pins and shorting the channels at the TT output connections but still could not get correctly centered stereo image.
I dropped into a friend's hifi store one day and he (Chris) said to me....'check this out'.
He played a known music passage and we both agreed that all was good.
He then flipped the direction of one interconnect and......the image skewed sideways.
WTF....and then the penny clanged, this is the problem with my turntable !.
When I fitted the cable to my TT, I stripped both ends and soldered these to the TT output connections.
I then cut the looped cable and fitted the RCA's....I was aware at the time that directions were reversed but discounted this as of no consequence because I had been taught/bludgeoned at college that ''cables/wires do not have directional properties.....and don't you forget it''.
When I got home I went straight to my TT armed with soldering iron and corrected the cable direction issue.
This corrected the image centering problem that had dogged me for months and suddenly all was well.
This experience later inspired me to make purposely non-directional interconnects.
The result was truly 3D sound, with sounds coming from miles through the curtains, and from miles behind the couch when playing natural sound recordings.
Sufficiently realistic that friends looked for rear speakers behind and to the sides of the couch !.
Music is an asymmetric waveform and this may be the key.....typical static testing methods run as perfect as is possible symmetric waveforms and rectification/averaging and therefore may not reveal minor/micro wire/cable asymmetries.
Thinking outside the square, maybe current direction very subtly changes noise spectrum including vlf or 1/f noise spectrum....dunno yet.
Dan.
As Scott said and as I have asked endlessly, why is this only something that happens in esoteric audio? This is one of the more stupid audio myths that distracts from the real issues and makes the hobby look silly...
Where is the proof?
Examples, citations, information!
As expected, building and running a 201 element LCR model shows no differences with a single cell LCR, nor the spice TL model, for an audioband risetime.And you'd be very worried if a large discrete LCR model did not match TL results. For audioband risetimes all three models should match well in any event. This must include the effect of source/load impedances shunting cable capacitance. BTW, this renders variation of the rf characteristic impedance of the TL irrelevant, as it should be of course.
Attached is a simulation of a 25uS risetime signal into a 4m cable with approx. parameters same as cable 7 from the Davis paper, a Beldon parallel pair, at JN's request. Total L 3.456uH, C 432pf, R 0.04R. The load in this image was 8R. It's easy to see the latency is c 0.432uS, which is negligible.
One might choose a lower impedance load and obtain more latency - 1R provides c 3.4uS, all as expected, and no significant difference between the 3 models.
I wasn't expecting an epiphany, and didn't obtain one. What was I supposed to discover using the 201 element LCR that the other models didn't reveal again?
For an audio cable to be directional would require that some material used in its construction had significant coupling between electric and magnetic responses - for directionality you have to sense both voltage and current. Such materials exist, but they are rare and have to be specially made from the kinds of things (e.g. certain ceramics) which are not a normal part of audio cables. Hence normal audio cables cannot be directional.fas42 said:Edit: the directionality thing would be all about the fact that every electrical part is made of up of real materials, which do not have the "perfect" properties so beloved in textbooks.
You mean that careful simulation shows that a single cell model gives identical results to a 201 cell model in the audio band? How can this be? It was only a theory, and everyone knows that theory is just the ignorant speculation of boring engineers with poor hearing. How could theory happen to be true?luckythedog said:As expected, building and running a 201 element LCR model shows no differences with a single cell LCR, nor the spice TL model, for an audioband risetime.
Why cables may be directional doesn't interest me - what does is whether they effectively form a path of good conductivity throughout their length, between the electrical parts they link. And often they don't, which is why a major tweak I virtually always carry out is to hardwire the complete system - having become very sensitive to the distortion artifacts introduced by poor metal to metal contacts I have a hard time listening to systems where this is an audible factor. I would be very confident that many of these directionality possibilities simply disappear by doing this mod ...For an audio cable to be directional would require that some material used in its construction had significant coupling between electric and magnetic responses - for directionality you have to sense both voltage and current. Such materials exist, but they are rare and have to be specially made from the kinds of things (e.g. certain ceramics) which are not a normal part of audio cables. Hence normal audio cables cannot be directional.
No, he's not. That would require actually having to do something.
You should hire yourself out to CERN or similar, you are more sensitive than some equipment I have seen in use for measuring these effects, its incredible.....
How does a poor metal to metal contact manifest itself in your world.....
- Member Areas
- The Lounge
- Speaker Cable lifters or stands?
