Power Soaks and Dummy Loads
With the resistors capable of far in excess of what I'll put thru them their value will be pretty constant for measurement purposes. For playing guitar attenuated though, I might want some adjustable filters and if the resistance increases with crummier resistors when hot, well it will decrease the load on the amp when it's also hot, maybe that's why some people like lightbulbs in their power soak, but it also makes the speaker quieter as things heat up.
The attenuators which use transformers (like the Marshall Power Brake) are interesting, but I'm not sure I fully understand the intent. They are somewhat inductive, and so are the speakers they emulate...the 'soak's' transformer is probably easy for the amp's transformer to drive, with a certain attractive symmetry about it, unless the inductance gets ridiculous and some connection becomes intermittent and the back voltage gets out of hand and arcing around. So the big advantage is that you can use all of just one big power resistor, and vary the attenuation and load on the amp via different taps on the transformer, or something like that (instead of normal soaks which are not even using many of the resistors inside on some settings)??? But the transformer is more expensive than a handful of power resistors (or is the because I get the resistors surplus). Some claim that pure resistance loads affect the amp's tone detrimentally??? I'm not sure I understand. I'm not sure I understand the transformer in the Fostex attenuator that has one; it costs about 8 times more than their similarly-rated simple L-Pad. What's the advantage?
...or wire it like this, for two units of 4Ω 1200watts, using 8 resistors total.
(if you get the 10 piece lot, that will leave 2 spares for replacing)
If you then parallel those two 4Ω setups....you'll get a 2Ω dummy-load @ 2400watts :wchair:
Neither work as you have shown.
The 10r 300W can take upto 54.77V, either DC or AC.
I don't know if that is continuous, or intermittent.
10r||40r gives you 8r. The 40r needs to be able to withstand the same voltage as on the 10r, i.e. 54.77V The 40r needs a 75W rating to match the same voltage as the 10r.
The total rating for the 8r will then be 375W. increasing the power rating of the 40r does NOT increase the power rating of the whole assembly, the 10r 300W rating determines the maximum voltage that can be applied.
If you use 43r 70W, then you get 8r113.
You can trim this down, until all of your loads match.
Theoretically 573r 5.2W brings the 10r||43r down to 8r0, but you can use any of the E24 series around that value.
Notice that the 70W + the 5.2W of the parallel combination 43r||573r add up to that 75W.
Lots of 8r dummy loads become very useful.
Giving 5r33, 4r0, 2r67, 2r0, 1r6
Try two 3500 Watt / 240 Volt hot water heating elements in parallel. Get a 5 gallon bucket with a sealing lid and install the elements through the lid. Fill with a [small] bleach and water mix or mineral oil and create a vent hole. Good luck overheating that.
I use the above with 4 elements to create two 8 ohm loads that can be paralleled for 4 ohms. They measure 8.2 ohms each. I also have two smaller separate 8 ohm non-inductive load resistors that are good to about 100 watts each on a heat sink with fans.
For those of you in the USA, Lowes has 3500 Watt / 240 Volt elements for $9.00 each. Buckets are also there. Get yourself a 1.5 inch speed bit, some RTV (or silicone) sealant and some lamp cord. You will be all set for an easy afternoon project.
