What is this part? - Alpine MRV-M500 IC3601
Trying to be helpful, IC3601
Excellent. Thank you. Did you buy the schematic? I have 2 more of these amps still I need repaired. 🙂
From the original amp I repaired I removed this IC. Did some checking and knew a 2092 wouldn't work there. The Vcc com etc were all in wrong spots.
What's the marking on top of the zener you are curious about? I don't have an alpine on the bench right now to check. Look up the diode marking on this website. It'll tell you what it is.
http://www.sos.sk/pdf/SMD_Catalog.pdf
