Suggestions for my shop party system
I've built several home audio systems in the past, but mostly just a copy of some of the experts here on the forum. What I'm looking to do on this I can't find a suitable example, if I missed it please shout!
Shop is 48x64x12, heavily insulated and finished on the inside. I'd like to do a 3-way system and I've already got an active X-over and 3 amps left over from other projects. I want the speaker boxes to ascent the shop's physical size, they are going to be much bigger than needed, but that's the point. Music is classic rock, alternative, but will have to endure the wife's newer pop stuff as well. I do want the ability to surprise the audience on occasion, ha ha.
So I was thinking, per enclosure:
Dual Dayton Audio PA460-8 18"
Dual Eminence Alpha-8MRA 8"
Totally lost on tweeter/horn driver ??
Price is not of primary concern and I'm open to all insight and suggestions. I'd actually prefer to go 21", but not sure what I think of that Pyle 21", most of the others I see are just too high when buying 4.
Many thanks
IMO with classic rock you will completely miss the boat if you don't include 15" drivers, I suggest 18's in dedicated sub enclosures and then a 3-way 15/8/1 top with a passive crossover between the 8" and 1" for 3-way amplification. Use the Selenium D220ti compression driver on the Pyle waveguide with crossovers at 800hz and about 3.5khz. All of this can be flown up near the ceiling if you like but if you do that just make sure the cabinets include steel brackets to lock all the panels together to avoid fall hazards
Fun project.
I run stereo 3-way in a similar size shop. One 2x18" and one 12" coaxial per side. Makes a lot of noise. I leave the doors open when working outside and it still gets loud with 100% reflected sound.
I have those mids and the selenium. Also have 15" kappalites. The 3 way top will sound good but a good coax will sound as good or better.
What's your budget?
Yeah, I realize 18-21" if overkill, but the physical size will accident the the size of the shop. When the cabinets are hanging off a 12' ceiling, I want them to be an eye catcher, part of the motif!
The shop is a fully climate controlled man cave, sorta, for lack of a better term.
Mounted high in the corners invert a normal design.
The sealed midranges are a pretty grim starting point.
There must be far better options available, not sealed.
The 2x18"ers will need about 15cuft tuned to 30Hz,
though 10 cuft tuned to 30Hz is doable with low boost.
rgds, sreten.
Great!
I have another idea for the tops but it requires 3 channels per top. It would have less lobing on the vertical plane. Same size.
Unless you have a pile of the 15's I would leave them out. They most likely can't keep up. Subs capable of keeping up with these boxes will add on another couple grand at least and will be overkill for just about all domestic listening levels.
No problem! I've learned a lot from this site, it's the least I can do 🙂
If you don't have a measuring mic mini dsp has one for reasonable cost. It will be needed to get perfect crossovers. It's worth getting for professional results. Once dialed in you'll know it. Everything will sound natural and life like.
It'll be quite the system once it's all dialed in.
Mmmm, problem #2, how often are you in Indiana, ha ha ha. 😀
I'm going to sit on this for a day or two, just to leave time for the; "Hey, wait a min, how about this or I forgot about...." type of situation!
I'm on a engineering project till early April, plan is to have all materials on-site by then so construction can begin.
