First One - mosFET amplifier module
That overkill sizing seems to be a tendency when using SMPS since the bias of the FO is high. The maximum constant power dissipation of the Hypex and AudioPower are quite low compared to their maximum available power therefore you need to really increase the SMPS size like using a SMPS1200 for such a small amplifier.
On the other hand Connexelectronic has power supply that are stronger and can withstand a much higher maximum constant power dissipation therefore a 500W would be fine.
My 2 cents.
Eric
I am inclined to buy this SMPS from AudioPower: DPS-400/S2-LV
Looks good, pinnocchio has that SMPS tested with the First One and compared with the new DPS-500/UR (unregulated).
Is this case good enough for two FO modules? Those heatsinks seams to be ~30x7x5cm.
There's no mention of k/W, the First One needs heatsinks of 0.4 K/W or less.
Danny, yes, I red that comparision. Btw., DPS-500/UR is regulated and DPS-400/S2-LV is unregulated. They both look very nice. Sorry to not have a comparision between DPS-400/S2-LV and SMPS1200A400. Both are unregulated, same price range, but DPS-400/S2-LV seems to have better quality parts.
I would strongly advise against the italian producer mentioned above. I ordered a smps from them a year ago and it failed the first day of use. Sent it back, they acknowleged their fault and promised to send a new one. Never got it! Instead i got cca 10 emaill replies stating that i will get it soon. They were just taking me for a fool ( i can quote their stupid apologies...but would rather not!). I lost 350€ with them.
@ back I have ran 4 modules from one SMPS1200A180 as shown in post #1749. I haven't tested to see how much it causes the rail voltage to sag as I was getting +/- 47V which is close enough for me. As long as you have a big enough heatsink to mount the modules it is no problem.
